with the head studs i do them hand tight with the allen key (using the arp moly lube)
with the main studs i have always had the machine shop do them becuase i get them to line bore it at the same time.
on my 4agte should the arp main studs or head studs be screwed finger tight only or should i tension them down slightly with a allen key
i have cleaned every thing chased the thread and used the arp moly lube
lost my instructions Damm..
arp site no info
searched "mixed results"
thanks
Finger tight is fine, although it won't hurt to nip them up a bit with the allen key. They will rotate slightly when you torque the nuts down.
Thankyou +rep
As mentioned, finger tight only on the studs, as per ARP recommendations.
http://www.arp-bolts.com/Catalog/Cat...atalog040.html
Yup, finger tight.Originally Posted by 7M-GTE MX73
What Allen key are you guys on about, My studs don't have the hole for one ?
They should, all ARP studs do.
errr mine didn't.Originally Posted by jimmmayyy
Did they have ARP stamped around the top?
Not that i can remember.Originally Posted by jimmmayyy
These are what i paid for.
These are what i put in.
Did i put them in upside down ?![]()
yehundo one and have a look on the other side but im supprized you got them all upside down.
Will check when the head comes off in a few weeks but i put the grease it came with on them and didn't notice writing or Allen key hole then, Maybe i missed it or got ripped off.Originally Posted by fixeruperer
upside down des.
mine that i put in a couple of weeks back i lubed with the moly grease, tightened by hand, then used a 4.5mm allen key (i think) to do them up a wee bit tighter (nothing over the top)
NB : make sure you chase the threads in the block.
Heh yeah probably upside-down. Those are definitely genuine.
Gasket isn't leaking. Well put them in the right way when it come apart soon![]()
