Results 16 to 29 of 29
Thread: R154 gearbox speed sensor
    Default Re: R154 gearbox speed sensor
    Quote Originally Posted by kemicalx
    Hmm, fair enough. Pretty illogical, but fair enough. I wouldn't have though a cable drive would be cheaper than a few runs of wire..
    Price could easily be made up with the differences in the sensor/sender costs and the loom - not to mention complexity on the production line should this make a unique loom.
    Though, i agree that its fairly illogical to have a digital dash speedo working off a cable.
    And although he doesnt have it anymore, dori dori had a factory manual MZ20 but might be able to remember if it was a cable or elecrical sender.
    I did a 1J swap on a GX71 which had a digital dash that was cable-driven, just screwed the cable into a mechanical sender on the box
    Don't forget the cost of the speedo sensor itself...
    Jun 2006
    Tasmania
    Bump and shit
    Anyone know if the electronic senders in the jzz30 and Jzx will drive the speedo on my jzx81 mark2 factory fitted with a digital dash? Or will I need to take the sender from the original auto and put it on my jzx90 r154?
    I used a JZX81 auto's screw-on electrical speed sender on my R154 and it ran the JXZ81 digital dash perfectly.
    Jun 2006
    Tasmania
    thanks for that
    another question, out of the three wires that go to the sender unit, im guessing one is the sp2+ terminal that goes to the ecu and the other is the sp2- terminal that also goes to the ecu, what is the third wire?
    i "trimmed the fat" off my wiring loom and i now want to get my speedo going lol
    use the pinout from this drawing: http://www.linkecu.com/support/docum...otaSpeedSensor
    but T the power feed to the sender from your 12V ignition feed that goes to the reverse light switch.
    The signal wire then goes to the dash cluster, the dash cluster then feeds a 4 pulse per revolution signal back to the ECU's SP1 terminal.
    Quote Originally Posted by skin View Post
    Just FYI.
    SP2 is the input from the speed sensor (not the speedo sender) to the ecu.
    It has nothing do to with the speedo.
    The speedo sender goes directly from the sender to the dash.
    on most JZX81's SP2 comes from the ABS ECU
    Jun 2006
    Tasmania
    Thanks
    So it doesn't matter putting the 12v reverse light feed onto the 5v feed terminal?
    Jun 2006
    Tasmania
    http://homepage.mac.com/rib_feast/Ch...Connectors.pdf
    So according to these body connector pin outs I find the yellow wire ( remeber all factory jzx81 wiring I just cut the plug off and later the wires right up into the loom) coming out of the white plug and take it back to the signal pin of the sender unit, earth one pin and tee off the reverse lights for the other one ?
    Quote Originally Posted by JP View Post
    Yeah, the UZS131 Crown was the same.
    Not sure why, as basically every other Toyota went straight from the sensor to the ecu.
    yep, use run the wires as you describe and it should work. Not sure why Link list it as 5V sensor power, it's 12V in the toyota's the sensor is used in.
    Just make sure you T off the hot side of the reverse light switch wiring.
    Jun 2006
    Tasmania
    Thanks heaps Mate
    Anyone got a part number for the jzx81 sender ?
  1. Toyota's Abbreviations
    By Radar in forum Tech and Conversions
    Last Post: 16-02-2008, 03:19 PM
  2. Fault Codes
    By Duk in forum Tech and Conversions
    Last Post: 24-07-2007, 09:42 PM
  3. IS200 6 Speed gearbox on 1G-GTE?
    By Karma Supra in forum Tech and Conversions
    Last Post: 02-05-2006, 10:47 PM
