Results 1 to 5 of 5
Thread: 2JZGE vs 2JZGTE intake manifold
    Brisbane
    Default 2JZGE vs 2JZGTE intake manifold
    Hi guys
    Not here to discuss whether you think it's a good idea or not, just wanting to know if anyone can think of a reason why there would be any problem running a 2JZGTE plenum/loom/ecu on a 2JZGE?
    Jan 2007
    Default Re: 2JZGE vs 2JZGTE intake manifold
    Yeah plennum wouldn't bolt on, it doesn't share the same ignition system so your loom and ecu are useless without a hell of a lot of work.
    The plenum could be adapted if you can get someone to cut and shut the runners, but not worth the hassle IMO. Plus you'll lose the ACIS in the GE plenum which is a good thing to have for a NA engine.
    As for the GTE electronics, forget it as stated above. The biggest problem is lack of a crank-mounted CAS on the GE engine, and getting one on there involves sourcing and installing a GTE oil pump.
    Brisbane
    2JZGTE oil pump hard to source? Anything else that would cause it not to work?
    well, the GTE would also probably be tuned different for the vacuum section of the map, since the GE has higher compression
  1. Ceramic coating intake manifold
    By Joshstix in forum Tech and Conversions
    Last Post: 24-09-2008, 11:45 AM
  2. turbo intake manifold design
    By IH8TEC in forum Tech and Conversions
    Last Post: 10-04-2008, 02:40 PM
  3. Which 4age intake manifold for turbo?
    Last Post: 17-10-2007, 08:34 PM
  4. 185 3S custom intake manifold
    Last Post: 09-12-2006, 06:15 PM
