Page 1 of 3 123 LastLast
Results 1 to 15 of 40
Thread: 9age??
    Junior Member Backyard Mechanic Bazooka's Avatar
    May 2006
    Default 9age??
    I came across something the other day about a 9A engine. Apparently this is a 7A bored and stroked to nearly 2 Litres. Sounds awesome but was just wondering if anyone else has ever heard of this?
    Default Re: 9age??
    how thick are the cylinder walls of the 7A? aren't they the same spacing as a 4A?
    maybe just do a quick calc to see what bore and stroke would be required?
    4A is 81/77
    7A is 81/85.5
    the wiki mythical 9A says
    A modified version of the 7a that brings the displacement up to or near 2.0L, done by further increasing the stroke and bore with either a custom crankshaft and/or adapting a 1ZZ or 2ZZ crankshaft using a 81mm 82mm or 83mm bore selection anything past 83mm will require the block to have pressed in liner sleeves. The method to reach 1990cc's is to have a 83mm bore with the 1zzfe 91.5mm stroke, both the 1zzfe and the 7afe crankshafts share the same main journal diameter and have almost identical bore spacing ,2zzge rods are almost perfect rods to used in conjuction with ca18det pistons this is a proven low budget stoker option with very little machine work.
    and wiki is never wrong or edited by ppl with little idea
    but sure it might be good. for a stroker or turbo motor
    Default Re: 9age??
    good old wikipedia
    the biggest can of lies on the internet since loosechange911
    lol
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    Default Re: 9age??
    Quote Originally Posted by wiki
    Meh, details, it's not like it's rocket surgery.
    Toymods Club Member
    Default Re: 9age??
    I love how they say almost this and almost than, then say a 1ZZ or 2ZZ crank (which are different, aren't they? 1ZZ and 2ZZ have different bore and stroke), 2ZZ rods and CA pistons, yet it's a "proven" (I've never seen nor heard of it) "low-budget" (my arse it is. Nothing is low budget once you need to do so much work on the bottom end) "stocker" (almost nothing stock left about it) with "very little machine work" (apart from offset boring the block so the crank lines up, and all the other work required)
    Default Re: 9age??
    1ZZ or 2ZZ cranks hey? That works how?
    1ZZ and 2ZZ have a different stroke length... I call shenanigans!
    Default Re: 9age??
    i though the increase in capacity was the different height of the blocks.
    id assume the engine would be very similar to the 4age in strength. Are they 7rib style?
    Default Re: 9age??
    1ZZ/2ZZ = different bore and stroke.
    height of block only affect length of rod.. or potential for onger stroke...
    while the wiki thing might be heresay, stranger combination shave been made (or potentially..)
    Default Re: 9age??
    i meant 4age to 7age but if they same applies ok...
    Default Re: 9age??
    the increase in capacity is due to stroke.
    the higher deck height just measn that can put the same size rods, with the longer stroke...
    Default Re: 9age??
    1900cc 7A is done by these guys: http://www.speedracersportscars.com.au/stroker.htm
    oregon
    Default Re: 9age??
    would someone explain to me what the advantage is of DUMPING $$$$$$ (or chose your currency) into an A block? You need 2 liters?? a 3SGE is quite a nice engine. prefer a bit more low end... stroke it... but taking an engine that at its smallest was 1295cc (2A SOHC) and increasing the volume by over 50%... just doesn't make a lot of sense to me.........
    SC14 7AGZE Grease Monkey
    Jun 2007
    FL
    Default Re: 9age??
    I have the most respect for alot of members in this thread because of their knowledge and contribution to this community, but for whatever reason I feel like some of you are "hating" on this concept instead of cheering it on and encouraging innovation. If it fits in, then great find. If not, well thanks for the attempt. Thats the way I look at it.
    Anyhow, it just so happens I have a 7A block, 7A crank, and 1ZZ crank all lying around my shop. So its time for a comparison. Here we go:
    1ZZFE crankshaft VS. 7AFE crankshaft
    1ZZFE crankshaft in 7A Block - Side View
    1ZZFE crankshaft in 7A Block - Top View
    These are with my camera phone, so sorry for the quality. But to sum up my opinion... I think it will fit, as long as you shave the sides of the block walls, as it seems the counterweights are slightly thicker and wont allow it to seat into the main bore. Thats the only "machining" I can see having to be done, out of my brief comparison. I havent measured, but the bore spacing is pretty much exact.
    It should all fit as stated in the wikipedia article, the only things that would have to be custom would be a flywheel and clutch, as well as timing gear and crank pulley. But this all beats the $2500 or more you would spend on a custom stroker kit. I wouldn't do it, but there no need to be a "hater" and look down on the idea. I'd guess to say it the custom parts needed could very well be made for $1000 or under given your resources.
    SC14 7AGZE build: http://beasted86.webs.com/
    Tasmania
    Default Re: 9age??
    nice, 1zz crank 2zz rods, 7a block, 20 valve head, dirty big snail.
    someone do it .
    1973 TA22
    Default Re: 9age??
    Hey, nice work! As potentially one of the 'haters', i'd just like to clarify my 'hate' was directed at Wiki and the quality of it's information, not anybody who went out and tried to see if this would work! That article was clearly not written by somebody who had tried it, and i certainly wouldn't start buying bits based on it.
    Your info on teh other hand, is really quite constructive... Can anybody give an answer to the earlier question raised on the relative strength of the 7A block to the late 4A? I know there's more than a couple 7A turbos getting about these days, what sort of power are they holding in with stock blocks?
    Toymods Club Member
