Only you can answer the 'is it worth it' question, as you will be forking out the dollars.
230kw is 306hp, or 102hp/L, which is very achievable, but in doing so on a stock bottom end you may lose a fair gob of low down power.
You are going to have to decide whether this would be an acceptable loss.
Is there any reason to stay with the 2JZ? Class restrictions?
Its just the a 1UZ will do 230kw with just a manual trans, extractors and a programable ecu, have more bottom end, and be 30-40kg lighter.
Also have mucho more potential if you decide.
But if you have class restrictions, that changes everything, and the 2JZ would be the best choice.
