Results 1 to 11 of 11
Thread: Ae92 Ewd's
    At Work I'm A Grease Monkey Hibba's Avatar
    Default Ae92 Ewd's
    I've had a look around and havent be able to find them anywhere, does anyone know where they can be had?
    Really looking for
    AE92 with 4AFE and AE92 with 4AGZE
    Trying to adpt body looms to each other and its hard with out diagrams
    MX83 Grande
    DirtyWan Skyline GX
    Auckland
    Default Re: Ae92 Ewd's
    might pay to just write "electical wiring diagrams" not that hard. search club4ag.com for 4agze ones.
    tracing the 4afe one will be easy once you remove the original 4afe engine loom.
    Then its just a matter of matching up the corresponding wires
    club4ag has the GZE wiring diagrams.
    Hoppers Crossing
    this is a long read, but, might help :
    http://www.toymods.net/forums/showthread.php?t=35523
    i've just put a 100kw 4AGE in my 4AFC corolla, so, kinda relevant
    Traditionalist Domestic Engineer parrot's Avatar
    I can help with wiring diagrams for a 90 series Corolla with 4AFE and 4AGE, but NOT 4AGZE.
    They are from the Toyota Electrical Wiring Diagram book for 1988 passenger vehicles.
    In the usual long format, but I am not able to scan them up at the moment. Happy to send you a photocopy later this week if you want to PM me your address.
    You may want them too Grega?
    Hoppers Crossing
    parrot ; if you're talking about the yellow books, i have them for the ae92 incl the 4afc, 6afc, 4afe and 4age so i'm covered - thanks anyway
    No worries.
    No, this is a book with all the EWD's for all Toyota passenger vehicles produced in 1988. But presumably would be the same as the one in a body/chassis manual. Definitely doesn't have anything with 4AGZE though.
    I should add, these are the line drawing schematic type EWD's, not the individual circuit with each connection in detail type diagrams.
    Yeh i really need the plug pin outs from the 4AFE engine loom. The 4 or 5 that actully go in to the car
    MX83 Grande
    DirtyWan Skyline GX
    Hoppers Crossing
    two plugs ; ones yellow, the other is black with three wires, black (or black/white if you're auto), black/red and black/orange?
    i can probably help you here. let me know
    there is..
    1 ECU Connector
    1 Yellow with 4 pins
    1 Black with 5 pins
    1 Black with 2 pins
    1 Grey with 22ish pins
    MX83 Grande
    DirtyWan Skyline GX
    Hoppers Crossing
    OK
    From memory
    1 black with 2 pins will have two THICK white wires - these come from the fusible links - 1 is 100A the other is 30A. If you had a 4AFC you will have one with only 1 wire. I only used one (30A) as thats all my AE92 uses.
    Not sure on the yellow with 4 pins
    The ECU connector will typically be the N plug or power for the ECU - should be about 12 pins I reckon. Most of these will transfer over to the new ECU but best buzz them out with a multimeter - I don't know what these will be. I had to add my own one of these as the 4AFC didnt come with this arrangement
    The black with 5 pins will have a black/white wire (starter)
    The thick black/red tracer wire will match up with your engine loom OK
    The thich black/orange tracer wire will also connect up with your engine loom OK
    The smaller black/red powers the ECU ect - buzz it out to make sure.
    Not sure what the 5th pin will be
    The grey F2 plug in mine was as follows (not all 22 pins were used I found)
    4 = 7.5A eng fuse
    8 = AC clutch
    12 = FP on chck terminal (blue)
    18 = Tacho (black)
    15 = Red/Blue (reverse lights)
    16 = Red/Blue (reverse lights)
    6 = Yellow/Green (temp sender)
    14 = Yellow/Black (oil press)
    17 = White/Black (ground for dash)
    9 = White/Red (AC)
    20 = Yellow/Black (AC)
    21 = Black/Red (AC)
    I hope this helps
    Ideally, buzz this out with a multimeter, check once, twice then three times.
    I did the above and blew not one fuse (and if it wasn't for cheap arse me not getting my injectors recoed my car would have start first go)
    Best of luck mate, any more questions fire away.
    By The Witzl in forum FAQ
  2. GUIDE - Cheap AE92 Quick Shift
    Last Post: 01-04-2014, 10:53 PM
  3. AE92 Master Cylinder Upgrade?
    By DiZ in forum Tech and Conversions
    Last Post: 26-04-2013, 03:40 PM
  4. 4AGE 100kw into AE92 (where 4AFC used to live)
    By Grega in forum Engine & Driveline Conversions
    Last Post: 24-07-2008, 06:53 PM
  5. GUIDE - Cheap AE92 Quick Shift
    Last Post: 22-02-2007, 10:23 AM
