i use a malpasi 2:1 rising rate fuel pressure reg.(for every 1 psi of boost you get 2psi fuel pressure increase) you can get it in 1:1 also
it works fine and has been in the car for 4 years. its about $150 and has a fuel pressure guage port. the ports are 1/8 npt
there are heaps of brands to choose from, the main difference between them is the:
flow: if you are running twin pumps you would go for a higher flow model with 1/2 npt or so ports so that at idle your fuel pressure will still be 40 psi by letting the high volume of unused fuel back to tank
fuel types: some can run methanol/ ethanol
good luck
