Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: 2JZ-GTE Boosting Issues
    Default 2JZ-GTE Boosting Issues
    OK.
    EDIT: I suspect something in my system isn't right See my next post for a better description...
    /end edit
    I need an exhaust restrictor in my 2JZ-GTE, it has 3" zaust (with cat), and front mount IC.
    Boost is not even close to controlled (Shoots off my 20psi gauge ). On a side not it seems that my sequential mode is broken, I only get ~5psi all the way when in sequential mode... note to self: check front turbo wastegate is working...
    A few people have done different things it seems..
    Norbie had a 3" -> 2.5" cone in his...
    BWMTurbo says 3" -> 2.25" cone...
    Project sleeper had a flange with a 2.5" hole in it...
    And some other sources say a plate with a 2" hole...
    While I'd like to try them all, as the same time I'd rather not!
    Last edited by wilbo666; 20-05-2008 at 11:58 PM. Reason: Changed to boosting issues
    Default Re: 2JZ-GTE Exhuast Restrictor...
    get a real turbo + external wastegate?
    consensus (well, majority really) seems to be that as long as it has a 2.5" hole in it somewhere, you'll have decent, controllable boost. afaik, the 2" hole is unnecessarily small.
    Junior Member Grease Monkey BMWTurbo's Avatar
    Jan 2007
    How much boost do you want to run Wilbo? I can hold 15psi ish steady with the roughly 2.25 cone.
    I had it at 2.5inch but had to reduce to add weld around the inside of the cone throat to reduce it's diameter back in order to not boost spike. I should also note I made a new transition from the factory cast 'butterfly' section to a single 3inch pipe. This smooth transition might be the reason I needed more restriction then other's have that have made thiers.
    My exhaust is a single 3inch, through a 3inch hi-flo CAT, 24inch long 3inch resonator, back out a single 3in dual 3out free flowing muffler.
    Default Re: 2JZ-GTE Boosting Issues
    Well it seems that something isn't quite right with my turbo system...
    In stock seq mode it will only make ~5psi all the way to redline...
    With my ETTC switch (diodes from the IACV VSV and EGV VSV at the ECU to a switch that GNDs) on I get massive overboost (20psi + off my boost gauge).
    So far I have checked the IACV and EGV and thier VSVs. I used a syringe to apply pressure and watch them actuate.
    I haven't checked the front turbo wastegate as yet, will do as soon as I can.
    In the mean time does anyone have any suggestions?!
    I'll be going over all the hoses etc later today...!
    Btw I now have a 3" -> 2.3" restrictor in place...
    Well checked the VSV on the front turbo wastegate...and it was stuck open
    My spare front turbo VSV had a broken nipple...so I had to take them both apart and make one good one from the two. In case anyone cared the 'broken' one had a little pieces of what looked like rubber about 0.5mm long floating around inside it that was causing it not to shut...
    So Seq mode now works (I would have thought it would have worked before, so I'm a little confused there..)
    And ETTC mode also works as expected...
    Even with the restrictor boost seems to be going pretty high...for testing I still have boost cut on atm, but will get rid of it soon and do some logging...see what it shows...
    Oh and a pic of norbs old dump...
    And the zaust
    Jan 2007
    Looks good Wilbo... 2.25 it is hey
    Well it is 2.3" already!
    Just about to turn boost cut off, go find a highway and see what it suggests peak boost is...
    Impressive problem solving!
    sounds like you're ready to run a mid 12 at the drags tonight
    could you have managed a straighter exhaust?
    This still isn't sorted...
    and after the drags the plot thickens...
    http://www.toymods.net/forums/showpo...&postcount=285
    It seems that even in ETTC mode there is quite a dip in boost and then it comes back on, it goes 5...dip, 18, check engine (no ecu code logged, and must boost cut defender is set so that the ECU sees a max of ~12.1psi [4200mV]...)
    I will have to keep investigating...
    Edit: Draven, I do what I can
    Datalog from the first drag race...
    Can see the boost dropping when the engine is cutting out
    Also
    http://www.toymods.net/forums/showpo...&postcount=290
    Jan 2007
    That in sequential mode??? you will get a 'dip' in sequential mode when the second turbo comes on line.
    How is the 'boost limited' to the ECU? Sounds like a EBC issue to me. Where is the EBC connected?
    Attachment 6800
    Yes sequential mode,
    NO boost controller fitted.
    THe boost is limited to the ECU via the same circuit that does the logging. My micro takes an ADC sample, checks to see if it is over 4300mV (or whatever I set) and then if it is over 4300mV it caps its output to the ECU to 4300mV. I'm using an R2R network for my DAC, so it is nice and simple.
    I've tested that the output is getting capped.
    I also tried 4200mV
    I think you are right tho, it does feel like the issue is in that ball park!
    estabane has a 'proper' boost cut defender that he can lend me to try that.
    I'm still not convinced that the rest of the turbo system is working correctly to be honest, so I need to go over the parts of that I havent checked yet (pressure storage, exhaust gas bypass...)
    User Conversion King
    NWA
    what sort of timeframe is there between the 'cuts'??
    the fake rev limit has a hysteris (spel?) more then the rel rev limit but less then the boost cut (right way around?)
    the fake rev limit cuts for about 0.3s?
    hello
    The thing is it isn't at the limiter....
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 06:27 PM
  2. 2JZ Water Pump onto 1JZ
    Last Post: 28-10-2008, 11:33 PM
  3. Exhuast Questions
    By Z2TT in forum Tech and Conversions
    Last Post: 10-12-2007, 07:45 PM
  4. 1jz to 2jz
    Last Post: 30-11-2006, 07:52 AM
  5. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
