Results 1 to 6 of 6
Thread: Coilover sleeve kits, what's the go?
    Chiba
    Default Coilover sleeve kits, what's the go?
    Well, I've got myself a spare set of front struts for my AE101 Levin. As my car has Superstrut suspension, off the shelf coilovers are few and far between... (I have a choice of TRD and Tein).
    I'm contemplating building a set of coilovers using those weld-on sleeves and KYB (or similar) inserts.
    My struts are 50.5mm in diameter, where can I get a suitable sleeve kit, and what's the go with working out spring rates, damper stroke and ride height? I have king spring lows in at the moment, which lowers the car by about an inch, and I wouldn't mind another 1/2 inch or so lower.
    Can anyone point me in the right directions?
    Thanks.
    Chiba
    Default Re: Coilover sleeve kits, what's the go?
    Will Celica ST204 inserts fit? They're the only superstrut inserts I can find on the KYB site.
    the koni sleeves are fine
    if you're struggling to work out bump and rebound travel, insert and housing length and etc for your application i recommned you buy the trd ones off the shelf, will insure you against trying to nut it out yourself and making a mess of it
    i pulled three hundred rocks from the land to build my house
    i walked quiet through the forest like a tiny quiet forest mouse
    the oceans will rise
    please stand by the shore
    Chiba
    I'll be able to work it out ok, I just need the formulas etc.
    Any idea about what inert are compatible with the superstrut struts?
    formulas?
    well for street use you want at least 120mm-150mm of travel minimum
    distributed to about 2/3 bump 1/3 droop travel from the static position
  1. Coilover sleeve and strut welding info needed
    Last Post: 02-09-2012, 08:57 AM
  2. Guide: Coilover Conversion
    Last Post: 18-03-2007, 08:45 AM
  3. Rear Coilover kits
    By 71RA20 in forum Tech and Conversions
    Last Post: 27-01-2006, 08:25 AM
  4. coilover sleeve lenght?
    By slide86 in forum Tech and Conversions
    Last Post: 18-01-2006, 06:18 AM
