Results 1 to 7 of 7
Thread: Which vacuum line for 1JZ charcoal canister?
    Don't Trust Me I'm A Backyard Mechanic Jabtronic's Avatar
    Gold Coast, QLD
    Default Which vacuum line for 1JZ charcoal canister?
    Just wondering which vacuum line I'm supposed to use for the charcoal canister on a 1JZ? As far as I understand I'm supposed to use a timed vacuum port but I don't know which one that is?
    I tried hooking it up with a normal vacuum source and it sucks air in through the bottom vent of the canister at idle. It's an MX83 canister and seems to have a built in one way valve already so boost shouldnt be a problem.
    Here's a pic of the lines.
    Default Re: Which vacuum line for 1JZ charcoal canister?
    AFAIK its always the one on the TB
    Gold Coast, QLD
    They all being used except the one that runs underneath the engine diagnosis connector. Looking at the diagram, it comes from before the TB so I'll try that. (It's the one that says refer to fig 77-01 on the right side of the pic)
    Apr 2007
    Yes it has to be what they call ported vacuum, which is only obtainable from the throttle butterfly, easy way to check is that it should NOT have vacuum at idle & the vacuum should increase as the RPM speed increases ...
    Yeh, i found mine came from the infront of the throttle body, but had a hard tube that wrapped underneath the plenum and popped back out on the wide down near 77-01. Or something around that anyway
    But it was painted black, i remember that... I'll get a pic if you need it...
    Jase
    JZA023
    Gold Coast, QLD
    I ran it to the hard line that comes out under the diagnosis box and it seems to work fine.
    When I used a vacuum line after the throttlebody it sucked air through the canister vent, but when I used the 77-01 line it doesn't suck air through and there's no change in revs so all good.
    17650 represents the electronic valve that was connected to my charcoal cannister... there may be another illustration available on the epc showings its correct installation...
    JZA70|R / 12.45 @ 111 mph.
  1. Charcoal canister lines
    By rogue-vl in forum Tech and Conversions
    Last Post: 25-04-2007, 12:17 PM
  2. Fuel smell under boost/cruising mz20 7mgte
    By Kedderz in forum Tech and Conversions
    Last Post: 19-01-2007, 08:51 AM
  3. 22re vacuum line help
    By ra65 in forum Tech and Conversions
    Last Post: 05-04-2006, 04:56 PM
  4. Replies: 12
    Last Post: 16-12-2005, 09:03 AM
