anyone.... so despreate.
just about to go wire up my four wire oxygen sensor, (as my car is only a single wire)
reason being, my sensor has been moved to the s2 postion, and needs a heater to work effectivly now,
Stock Toyota 4 wire
can anyone confirm if this is correct
Black -Heat (+12vdc)
Black-Heat (-12vdc)
Blue-Signal (ie connect to my original wire)
White-earth (connect to chassis)
__________________
so i dont blow it up
1990 Aus Delivered Widebody GT4 Play 200 awkw
1996 HDJ80. turbo multivalve 80 series landcruiser
1997 HZJ80 Landcruiser Sold![]()
1993 Soarer V8 Manual Sold![]()
1986 Celica SX Sold![]()
Yes thats it except the white goes to E2 of engine wiring sensor earth
Dave
Yeah, and technically there isn't a -12V... it's just ground.
Black - O2 heater circuit ground
Black - O2 heater circuit 12V
White - Sensor circuit ground wire
Blue - Sensor circuit signal wire
so with white i can just ground out
to the body, or it has to go to a specific negative
remembering the car is just a one wire from the factory
Yeah, there's no harm in doing that.
The 1-wire sensor just grounds through the O2 sensor body anyway, but they changed to a 2-wire (with an isolated sensor housing) to avoid relying on grounding through a potentially dirty/corroded thread on the sensor.
it is better to ground it to the earth that is used for the ECU, because the signal is small (0-1V) and any difference in voltage between your choice of ground and the ECU's ground, will result in an incorrect reading.
you want the ECU to have the best reference possible, and 0.1 or 0.2V out is far too big for it to work properly
yes chassis could work, but you may as well as least extend the wire to go to the point of chassis where the ECU grounds..
Then the 4-wire adds a heater element. There was also a 3-wire that didn't have an isolated case and grounded through the case.
Yeah, it would be worth the effort.Originally Posted by oldcorollas
ok
i got plenty of grounding cables going back to the battery, it would be best to come off one of those, as frankly i have nfi where the ecu grounds
ok finished now, turned out the signal wire had an integrated earth sheath, so i used that as my sensor ground,
for the power i was under the impression that i could just tap into the alternators on wires with a fuse would be fine, however the battery check light is now onstill charging correctly
but overall good as the engine is now not running uber rich now, but only time will tell if my economy will return
anyone suggest a better place to tap in ?
Does the heater stay on all the time normally, or is it only on long enough for the o2 sensor to heat up?
If it's on all the time, couldn't you just wire the heater to the ignition, via a relay?
all the time as far as i am aware,
yes i could do that, looks like the path i will be taking, but it is such a small load (12w) i did not think there would be an issue
That's about 1 amp, which isn't insignificant, but shouldn't need a relay.
Obviously if you run it direct from the alternator or battery, then you will want to run a fuse.
To keep it neat, I probably would have run 4 new dedicated wires to the ECU rather than one to the old connector, one to the chassis, one to the ignition, and another to the chassis. You could just tap all the wires into the loom at the same spot.
The heater power to the Ignition input of the ECU, and the heater ground to the the ECU gnd.
The signal to the signal wire, and the signal ground to the ECU signal ground.
But, there are many ways to skin a cat and the important thing is that your is working now![]()
well i will have to resolve the battery light being on, but i am sure il will sort it out,
does anyone know where the s2 gets the oxy sensors power from \
