Results 1 to 15 of 17
Thread: ST185 Celica GT4 Aus Spec brake pads
    Junior Member Grease Monkey Camryman's Avatar
    Default ST185 Celica GT4 Aus Spec brake pads
    Just wondering if anyone knows if there are off the shelf street performance front brake pads for a ST185 Celica GT4? Bendix only have general compounds.
    Default Re: ST185 Celica GT4 Aus Spec brake pads
    Ferodo DS2500's
    Exceptionally good pad for street and track use.
    27.90s @ Esses Hillclimb
    Cool, thanks
    Quote Originally Posted by Roundy
    Ferodo DS2500's
    Hey Dude,
    Is there a part number for these pads? I downloaded the pdf catalogue but there seems to be a mysterious whole for the ST185
    Bit of searching and i found it i think
    They come under the Ferodo Motorsport division, not Ferodo by themselves
    FCP602H
    Should be the right number, tho it is an older one, i have had them for a while now
    Thanks Dude, that is a great help!
    Piece of trivia here. The Ferodo FCP602H brake pads will also fit stock Camry SV21.
    http://www.fm-ecat.eu/fsp/CarSpecs.asp?pn=FCP602
    queensland
    are the Aust spec calipers the same as the Camry or something else???>
    Quote Originally Posted by terryo View Post
    No.
    The long answer is that Aust spec GT4 calipers and rotors bolt straight onto the front of a Camry. I think the GT4 calipers are the same as the Celica ST184 if memory serves correct, or at least they share the same part number for brake pads.
    As well apparently the JDM GT4 twin piston calipers will fit the Aust spec Camry without having to change the rotors, which are smaller than an Aust GT4 calipers.
    Severely Underqualified Domestic Engineer Fodder's Avatar
    Pretty sure the series 2 ST184s got the big single pots, same as all the ADM ST185s. Earlier ones had inferior brakes but don't know exactly what.
    Normally Aspirated Domestic Engineer RT104GT's Avatar
    Quote Originally Posted by Fodder View Post
    anyone know the size of AUS rotors so I can check the size against my JDM front rotors and the part number of the pads.
    The calipers are four piston.
    my JDM rotors are FIXED
    1968 RT40S Corona 1600S series II (restore in progress)
    1973 RT104-MQFG 012604 Corona GT JDM (Owned since 1976 242000 km)
    1989 ST185-BLMVZ-0007199 Celica GT4 JDM (unmolested classic 95000 km)
    2012 ZN-6 86GT (shed find 5000 km in 6 years)
    278 x 25mm (i think it is 25mm thick)
    Maybe ST184/2 rotors will fit the JDM, they are smaller than the GT4 ones.
    queensland
    the Australian GT4's all got the Group A brakes which had larger rotors front & rear, compared with Jap Gt4's. The rear pads are the same, but the fronts are different. The front 2 piston Jap brakes are unique however the Aust GT4 front calipers have the same pads as some very late 184's. The rotors are different 185 to 184.
    all the different Toyota pads can be got at www.roadandtrack.net.au
    FYI, surprised but I just fitted DB1181 to my ST185 JDM
    thats the part number listed for Aussie delivered as well and yet they fit mine as you can see..
    A supercheap guy matched the old pads with a template in the bendix book.
    But there seems to be confusion as with the Db1185 Subaru fitting the caliper as well.
    see above
    That isn't the aus delivered pad.
    I have been caught out with that one early on.
    ADM GT4's have the DB1129 pattern
    By The Witzl in forum FAQ
  2. Grease on backs of brake pads. Essential?
    By DigitalPho3nix in forum Tech and Conversions
    Last Post: 12-01-2006, 06:43 PM
  3. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
    Last Post: 08-09-2005, 01:27 PM
  4. Brake upgrades for FWD/AWD 5x100
    Last Post: 07-09-2005, 12:38 AM
