Results 1 to 15 of 24
Thread: Shock Absorber strut listing- Urgent need 300mm long
    West Australia
    Default Shock Absorber strut listing- Urgent need 300mm long
    Hey Guys,
    in an attempt to keep the Mark II going i need to replace the front shock cartridges asap.
    They are a simple strut type :
    The issue is that i need a short stroke style cartridge.
    The length needed is 300mm long or (303mm MAX!)
    Also diameter of the cartridge being 50mm or under.
    I have had a look into SW20/ST185 and they are the closest ive found.
    SW20 = 360mm
    ST185 = 345mm
    Does anyone know how to obain a Gabriel/Monroe/KYB product spec PDF or similar so i can do some more research .. as they are impossible to find on the official sites.
    I would even go Nissan if i new anything about them. And if any of you do ? please help me!
    John.
    Default Re: Shock Absorber strut listing- Urgent need 300mm long
    Quote Originally Posted by coffee
    John.
    I got a monroe paper cat when I emailed them...
    I'll have a look through for you if I get a chance...
    Edit: I can't have a look at my paper cat, I've lent it to thechuckster
    But I found the CD they also sent me So I'll have a look at that...
    Wilbo's JZA80
    Wilbo's JZZ12
    West Australia
    cartridge length (the black bit) 300mm
    GO WILBO!!!!!!!!
    Send me your email address
    I found the PDF version of the 2006 paper cat... I don't have any hosting or I'd host it
    Not looking good tho, shortest I found is...
    317mm: 25-0826+ VOLKSWAGEN - Golf (Series I & III), Convertible 79-93,VOLKSWAGEN - Golf (Series I), Hatchback 73-8/83
    Actually...
    270mm, V-3001+, Suzuki - carry, ST90V, Van, Standard, 2WD, 1982-1985, Front
    (It says 'other' cartridge type tho...no idea what that means!)
    Wilbo's JZA80
    Wilbo's JZZ12
    West Australia
    Suzuki hey ....
    i wonder how thin the cartridge is though. ..
    and how much damping it would give?
    have you gone to toyota and asked them? don't they use tokico or KYB as stock inserts?
    why not call an actual shop.. and you know.. ask them if they have anything in stock?
    or is that too obvious for you?
    I hosted it... (Note, hosting may or maynot work, let me know lol)
    http://www.mediafire.com/file/myo2to...monroe2006.pdf
    Wilbo's JZA80
    Wilbo's JZZ12
    West Australia
    if only OC
    They are JIC coilovers.
    Toyota wont care, and JIC coilovers use JIC shocks. Which are blown ... did u even read my initial post ?
    Call an actual shop ? and what ? say "do you have any dampners cartridge that are 300mm long"
    they will say "yeah we can custom make one for you, $26256908029824"
    JIC are shit
    oh.. you are finding that out now
    yah i read your post. you didn't mention JIC at all
    Hey Guys,
    SW20 = 360mm
    ST185 = 345mm
    John.
    yes. call Kmac an ask. they can do custom shocks for not much.
    alternatively, give up on the JICrap, and just order TEINs...
    A decent shock place might be able to recon them...i.e. the WA equivalent of 'Shockreco' over here... http://www.shockreco.com.au/
    Another option might be to look into rear motorcycle shocks? lol
    Wilbo's JZA80
    Wilbo's JZZ12
    West Australia
    anyone got a link to a gabriel cat ???
    that monroe cat makes no sense ... where does it say the dimentions/size of the cartridge ???
    On page 189 it tells you the different types of inserts (with a pic and dims), i.e. T1, T2, T3, T3, T5, T6.
    i.e. POST, TYPE, BODY, COMP, EXTN, ROD NUT, etc
    On page 135 "NUMERICAL LISTING – CARTRIDGES" it tells you the dims of the shock inserts for different cars!
    Also given that mr oldones, has indicated that JICs are rebuilable, why aren't you simply exploring that option?! Makes more sense to me!
    Wilbo's JZA80
    Wilbo's JZZ12
    sux as a Grease Monkey
    Try calling KYB, usually they are really helpful: http://www.kyb.com.au/contact.htm.
    Link to pdf catalogue, but doesn't give dimensions.
    http://www.kyb.com/catalog.htm
    89 ST162, Extractors, Muffler, Suspension, Intake, white dials. More to come when I get money...
    Originally Posted by Javal
    ...squeak like a rat in a microwave...
    Junior Member Domestic Engineer ill-minded's Avatar
    May 2006
    not sure if it's much help, but the trd damper list lists a few around the 300mm mark
    48511-AE140 - 301mm
    48511-EP840 - 301.5mm
    48511-ST040 - 295.5mm
    48511-ST050 - 301mm
    they all seem to be about 43mm OD too
    listings are from here
  1. Guide: Coilover Conversion
    Last Post: 18-03-2007, 09:45 AM
  2. Is this usable? (MA61 strut shock)
    By Brett in forum Tech and Conversions
    Last Post: 15-10-2006, 09:21 AM
  3. Your suspension & you...
    Last Post: 23-05-2006, 08:41 AM
  4. shock absorber bolt?
    Last Post: 21-03-2006, 09:16 PM
  5. Front Shock Absorber Dimensions...
    Last Post: 18-10-2005, 01:58 PM
