Without being an expert on the cars, I would think that you would have to go through the paneling, (Perhaps Hiro is refering to the sedan....which probably does not have plastic trims, only carpet up the sides...) to open the fuel door.
if there is a compartment in that side (plastic trim) have a bit of a feel around in there, if there is a lever etc, it will be right near the fuel neck also have a look in the manual they may have something in there ..... I know that Falcons do.
If the pivot is broken on your lever set up, you may be able to cheat it, by pushing down and pulling the whole lever forward at the same time.
Good luck
