the positive side of the coil needs and ignition feed only, not a 12 volt feed from the battery.
(the ballast resistor will be a somewhat pathway for the 12 volt ignition to travel through...ie
ignition feed to one side of ballast resistor
wire from opposite end of ballast to positive side of coil.
the negative see bellow - (edited because i am a tool, and wasnt thinkin right) - (to the negative side you will also need to attach a feed to your tacho because otherwise it wont work.
good luck, let us know how it would go.
Jamie
