Results 1 to 4 of 4
Thread: 1JZ Oil / Water Fittings
    Default 1JZ Oil / Water Fittings
    Hey guys, im getting some braided lines made up and need fitting sizes for the Oil Feed and Oil Return and Water feed and Water return on the 1JZ for the single turbo.
    Also, if you have a idea on length would be sweet!
    Obviously i just need engine size fittings as the turbo sizes will be known
    Jase
    JZA023
    Default Re: 1JZ Oil / Water Fittings
    Of 28 people who has read this thread, no one can tell me what size fittings are required to make oil / water lines on the engine side of things??
    Someone has said water lines are just 10mm hose, and that does seem it could be right, but surely those solid lines screw in somewhere else?
    Jase
    JZA023
    GZE Love Grease Monkey PsyCo's Avatar
    Jan 2009
    The block oil feed is 10x1.25 so a speedflow 352-3 or -4 should suffice with 200 Seires teflon inner line. Depending on the turbo it may pay to pick up a speedflow inline restrictor as well. Nt sure what size the water is though sorry. Got it written in my book at work but I'm on holidays till sunday.
    May 2006
    Hey champ, i used normal 10mm for my water lines... and just put heat wrap around it , and the the braided line was already with the turbo, i had to modify the drain a bit because it was off a chaser... here is a pic
  1. water injection pre turbo
    By project_x in forum Tech and Conversions
    Last Post: 28-03-2008, 08:41 AM
  2. Water to Air intercoolers...input needed
    By 79GT in forum Tech and Conversions
    Last Post: 06-03-2008, 06:03 PM
  3. 1JZ water temp climbs 10 degrees within seconds of hitting boost
    By 1JZ-Rolla in forum Tech and Conversions
    Last Post: 10-02-2008, 10:50 AM
  4. 1JZ to 2JZ GTE water pump woes
    By ZZT231 in forum Tech and Conversions
    Last Post: 01-06-2006, 07:04 PM
