just use a sandwhich plate. easy and cheap,
you can also get the plates with thernostats in them to aid in the oil reaching operating temp quicker......this is how i run mine.
Chasing info on how others have fitted engine oil coolers to their 1GGTE. Have you used sandwich plates or are their input and output pick up points available?
Craig
ino5nt
do you have pictures?
when would you need to install an oil cooler for street or strip use ?
manuel
can u get a sandwich plate with the oil thermo in them can you??Originally Posted by IN 05 NT
Z20- SOLD
where did u get that from mate??
Cheers Deano
Z20- SOLD
interested in where to get sandwhich plate with thermistat for 1jz
87' z20 Soarer - 1jz Gt35r -
I'd be very surprised if Motorsport Connections didn't have something to suit your needs.
http://www.mscn.com.au/scripts/prodV...?idproduct=353
My KE25 thread
Im just setting up a remote oil filter/oil cooler on ma 1g at the moment,
does anyone have any advice on whether to run pump-filter-cooler-block or should i go pump-cooler-filter-block. thanks for any advice., also i was considering putting in a small accumulator, do you think this would be worth it for a hill climb/circuit car?
GA23(never finished-now with cracked block) JZX83 (Tyre eater) 3sgte AE86. by now i should know better.
This is theory only and a passing thought but I would be tempted to try a 3T-GTE sandwhich plate.
The 1G and 3T take the same oil filter![]()
1971 2T-B Celica TA22 ST.
1975 2T-G Celica TA27 GT
1985 3F Auto FJ62 Landcruiser
If i was to get the kit from justjaps for my 1G..Originally Posted by YLD-16L
Could i just swap over sandwich plates and run the one with the thermostate??
Z20- SOLD
Ebay has them.Few on there at the moment.
Cheers Brett.
On the topic of oil coolers.. I always think its a good idea to measure your oil temps first before going to the trouble of a cooler..
I was dead set on having an oil cooler on the 3sgte as it hits up a reasonable amount of track days..
I fitted a VDO oil gauge in the sump and i've done numerous wakefield and eastern creek days, often in 30 + deg days and never had the oil over 105 deg. This is after 8 - 10 hot laps.
Admittedly I have a 6.5ltr sump on the 3s, but just throwing it out there that sometimes its worth deciding if its actually needed first.
Once you fit an oil cooler there is a lot more failure points.. more oil line, joints, etc.
i was just going to fit one when i fitted up all my gauges etc.
So do u rekon the go is to get the justjap cooler kit and get a sandwich thermostate??
Z20- SOLD
whoops, sorry for the late reply, got it from autoone in waitara (hornsby) i think it was around about the $70 mark, there may be pics in my HO00NS thread, but you will have to dig thru them,
Originally Posted by TurboRA28
Very good point Joel.
I did the same but found I needed one at the track as oil temps were heading up to 120 and would have kept going up if I persisted in staying out on the track.
I'd have never needed one for on the street though, the temps never got above operating temp.
Added bonus is the oil cooler aids in coolant temp at the track too, very much needed on the little KE with small frontal cooling area and tiny sump volume.
My KE25 thread
