I remember my mechanic telling me that they are a common bearing. As in $2 common bearing which is still working fine in the end of my crank.
HI
Anyone know the dimensions for a R154 1JZ-GTE spigot bearing?
what price ranges are they?
Thanks
Rogue-VL
take it off and give it to a bearing place to match.
Its a 6201 bearing, should be less than about $5
thanks for all your replies,
celica_john- I have a auto JZZ30 front cut, so it doesn't have a spigot bearing thus the reason for requesting the dimensions
edwagon- what brand is that part number?
6201 32mm OD, 12mm ID.
Same as WRX (unsure of year model though). My clutch supplier gave me one when I got a custom setup made a little while back... had WRX written on the box. As everyone else has mentioned, definitely less than $10.
Thats a pretty universal part number, any bearing place (even dreaded repco) will be able to look after you if you quote "6201"
If you go on the excedy website and use the clutch finder, they will give you the part number for the spigot bearing your need.
Check it out, its on the side under additional parts not included.
http://clutchfinder.exedy.com.au/
wow that is really helpful!
