hey on garagedori.com theres a guy called waz he went from t3t4 to a t28 as he found it to laggy it was manual tho i think he is on here also
i had a t3t4 on my auto didnt find it to bad on boost but only drove it once
Im just looking for a bit of advice on selecting a turbo for my daily driver GA70 supra with
1ggte engine, I have all the supporting mods now I just need to pick a turbo. It's between either a TD05-16g, TD05-20g and a T3/T4 57 trim below is the specs for the T3/T4 and TD05-20g
T3/T4 57 trim
.50 A/R compressor.
.63 A/R V-band exhaust housing.
57 trim T04E compressor wheel.
6psi wastegate actuator (adjustable)
Intlet measures 3.00"
Outlet measures 2.00"
TD05-20g
68mm outlet exducer
52.65mm outlet inducer
55.85mm inlet inducer
48.92mm inlet exducer
2.50" inlet
Adjustable wastegate actuator
The car is auto and I am looking for good response above everything else but I would also like to know what sort of power each one could produce at 1 Bar. I did a search and found out that the gt28 is highly recommended as a good all round choice, are either one of these 2 turbos a suitable equivalent?
Any help or advice on this would be greatly appreciated,
Super T-70 Turbocharger.
Brad
1977 Toyota Corolla KE35 - Undergoing 4AGTE transplant.
1994 Ford Falcon Pedovan - Rape Dungeon
Get a ball bearing GT28RS or 2871R. They spool brilliantly and in the 2871R trim support 440hp.
RA23 - Twincharged
JZZ20 - Daily
Out of those 2 turbo's you definately want to be going with the TD05 as the T3/T4 would be very laggy on a 1G.
But for a good turbo on a 1G I'd be listening to Kedderz on this one.
1JZ MZ20 Soarer - 4AGZE KE70 Corolla - 4AGE AE86 - 4AGE KE70
If it were me, I'd probably look at a KKR380. Most people with the KKR stuff seem to be happy, it'd be responsive and performant, and about 3/5 the price of the Garrett stuff.
That also is another good option too...
Nothing beats a Super T-70. I mean there is lag but when it comes on it kicks like an angry horse!
Definately go with the TD05H-20G if you can get it cheap enough.
Will go to 220-240rwKw with excellent Boost response.
Otherwise the GT28R range is also a very good option if its not much more $$$.
thanks for all the replies, yeah I heard that the gt28 was the one to go for but they are way out of my price range. I asked a few workshops and tuning shops for advice and they all said to go for the t3/t4. Theres only like a $70 difference between the two turbos. what kind of rev range would a super t-70 begin to build boost at? I want a turbo that makes the most power at the same rpm (or lower) as the ct12's.
My bros comes on at around 4500 5000 lol.
When she signs on, hold on.
Brad
There is no way a t3/t4 will build boost at a similar threshold as the ct12s, they are TINY. If price is an issue get a kkr380
RA23 - Twincharged
JZZ20 - Daily
wow 4500-5000 thats high! Most of all it has to be drivable. Im probably going to use a TD05-20g.
Yeah it seems high, but its actually quite driveable, well I spose coz its in a KE30 weights nothing, but off boost its still quite perky. Then you just wait a bit and the thing is all over the road.
Brad
Out of interest has anyone here done a KKR380 on the 1g? I had a quick look at the stats and my initial reaction to them is that they would be a lag monster...I just bought a GA70 yesterday and was suprised how long the turbos take to come online for a stock car as is... (around 4200)
..perhaps the best thing to do is check what others have done and how they've reacted to similar setups to yours...can I ask hpw you narowed down your list and why theres no 'disco potato' on it? (GT28RS)
