Results 1 to 15 of 27
Thread: 7MGE TVIS vacumn hose
    Low rep 1st year Apprentice
    Default 7MGE TVIS vacumn hose
    hey guys
    im having some trouble finding where the vacumn hose from the TVIS diaphram in the middle of the intake manifold goes.
    the hose is there, there is just nowhere to connect it too!
    help would be appreciated, thanks!
    Carless Grease Monkey
    VIc
    Default Re: 7MGE TVIS vacumn hose
    pics will be encouraging too! Also check the online TSRM for 7MGE.
    Doesn't the 7MGE have ACIS instead?
    Hide Yo Kids Hide Yo Wife Carport Converter hamgatan's Avatar
    theres no TVIS on the 7M's.
    most hoses on the 7M's also go into the throttle body.. this might help
    JZZ20 1988 Soarer GT Twin Turbo
    1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
    does anyone in the hills have a N/A MA70 i could have a look at maybe?
    VIc
    Some rare 7M had TVIS I guess! So you might be the lucky one.
    Penrith BC
    its ACIS, and the vacuum hose goes down under the intake manifold to an SCV connected to a med sized metal air vacumm reservoir
    ../delete/ban
    tech moderator
    As stated, it's ACIS.
    Basic rule of thumb...Cressida motors didn't have it, Supra motors did have it.
    Default Re: 7MGE ACIS vacuum hose
    Spot the difference.
    No ACIS.
    ACIS.
    That top pic minus the ACIS is a damn tidy 7M engine bay!
    my mistake it's the ACIS engine, i was told it was TVIS
    im unable to find any info about AVIS on google though?
    my understanding is that its a butterfly that opens the 2nd intake port when manifold vacumn is increased?
    would taking this butterfly out altogether be a bad idea?
    the engines just feeling like its running out of puff after about 4000rpm, but it's a really smooth revving engine all the way to limiter, just feels like its restricted somewhere and im counting on it being the AVIS
    heres a informative dot and line to specify the diaphram and hose im talking about.
    Penrith BC
    nope thats just a crappy stock 7m they dont flow well, and hit a wall around 5k
    ACIS on or off really doesnt make much difference on the backside dynometer
    ""Acoustic Control Induction System:
    The ECU controls the position of the intake air control valve based on input signals from the throttle angle (VTA) and engine RPM (Ne). The VSV, which controls the vacuum supply to the actuator, is normally closed and passes vacuum to the actuator when it is energized by the ECU.""
    ../delete/ban
    tech moderator
    Quote Originally Posted by JesseCrown
    If you search on AVIS as you've said in your thread all you will find is truck rental companies. Search on ACIS. Read through the links I've posted in the thread above, they give a good rundown. Ed would know about the 7M more than me, but if it's anything like the 2J, it make a massive difference when it's not there. Investigate www.supraforums.com as well, this is a much covered topic there for the 7M.
    Quote Originally Posted by ed_jza80
    If it's anything like my TVIS, it'll make a big difference if it's locked shut. My car was a demon...to ~4000rpm then choked itself to death.
  1. Getting Good Vacumn Signal from Quad Throttles to Air
    Last Post: 14-02-2006, 05:09 PM
  2. TVIS or not to TVIS...
    Last Post: 12-01-2006, 07:46 AM
