any one?
Hey guys after a 10mm bolt on spacer...if they are available..cant seem to find any anywhere really?
Dont really wanna go for 15mm.....10mm would do the trick just fine if u can get them..
Needs to be 5 stud![]()
Z20- SOLD
any one?
Z20- SOLD
maybe 10mm is a bit small to be able to fit the head of the bolt in them, and still have enough strength to stop your wheels falling off at high speed?
Can get them from japan but i wouldn't trust them due to the size of the nut needed to hold them.
id prefer to put in longer studs and run slip-ons to tell you the truth but the choice is yours.
Originally Posted by WHITCHY
hmmm yeh ok fair enough..
Where can u get loner studs from?
Can u get 10mm slip ones or just run 2 5mm?
Z20- SOLD
like these?
You can but anything with cash![]()
I can make them mate......
how much would it be to make them for the front mate?
Z20- SOLD
Depends on how you want them made?
Ie just a flat spacer will be cheaper than having a locating ring on the spacer.
If you could draw something up with measurements etc ill beable to tell you a price.
Deano , you can get 15mm bolt ons from the USA for ~190 delivered.
only thing is , at that smaller size, your standard studs will stick through past the spacer and you will need the correct type of wheels to put on that have gaps between where each stud would go through
I got these off eBay from the States for about $70 inc shipping
nice and light and well made in the correct Toyota hub size, presumably if you didnt want 20mm you could get someone to turn them down on a lathe?
^^ do they even have a recess/correct angle for the wheel nuts to hold the spacer on??
Signiture edited..... Read the Rules
you can use 10mm wheel spacers, if the back of the wheel is voided to acomodate the nuts protruding...but not all wheels are like that.
longer studs ftw though!
its not a bolt-on job, its hubcentric so it aint going anywhere (hence needing to get the correct size for your hubs)Originally Posted by Disturbed1
Yeh u can get them from justjaps 2 dude..will have to check the back of my kakimotos and see what they are like...Originally Posted by coFF33
Any1 suggest anywhere to get longer wheel studs and the 10mm wheel spacers?
Z20- SOLD
What would u recommend?Originally Posted by 30psi 4agte
Im guessing the one with a locating ring would be safer wouldnt it?
Z20- SOLD
