Results 1 to 4 of 4
Thread: Valve seat cutter use?
    Default Valve seat cutter use?
    Anybody got experience using neway valve seat cutters on the toyota valve seats (7M in my case)?
    How hard do you have to press when turning the cutter around?
    Do the cutters need regular replacement?
    I bought a second hand set and dont know how sharp the cutters are relative to a new set.
    Default Re: Valve seat cutter use?
    Im not fimilar with NEWAY only NEWEN and they had special tip grinders for their cutters. Not cheap tho.
    Why is there any doubt? Does the cutter chatter on the seat? If it does, the pilot may not be tight enough, the cutter may be blunt or you may be applying incorrect pressure and or speed to the tool.
    Quote Originally Posted by jeffro ra28
    Neway cutters are mostly hand operated, although you can buy a power attachment.
    Here is a link to the local distributor.
    http://www.newayts.com.au/seatguiderest.htm
    I haven't even used them yet, I have to order a pilot and a T handle so I cant say if they chatter or not yet.
    Its really only the 60 degree cutter that I want to use to open the the throats up a little.
    I will do the 45 degree seat just by hand lapping and the 30 degree top cut is already there.
    Tallahassee, FL USofA
    Quote Originally Posted by amichie
    The 30 & 60 are used to set the seat width - wide or narrow - how long it will last& how well it will dissipate heat & how well it will break thru the carbon buildup, and sets where the seat contacts the valve face - bottom or middle or top - how big the valve size really is compared to just saying that it is the width of the valve head.
    Last Post: 29-02-2016, 12:30 PM
  2. Valve Lapping/Grinding Writeup
    By RobST162 in forum Tech and Conversions
    Last Post: 07-01-2009, 10:55 AM
  3. fill in the blanks! 1uz specs needed... help !!
    Last Post: 10-01-2007, 11:01 AM
  4. Computer Engine Modelling, (18rg in particular)
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 08-01-2006, 11:20 PM
