Results 1 to 8 of 8
Thread: Auto to manual conversion
    Jan 2009
    Default Auto to manual conversion
    Hey guys,
    I have a 1976 TA23 with original 1.6L and auto box. The box is on its way out and i want to keep the engine (only for lack of $$ at the moment) and swap it to a manual. What is involved in this and how do i track down a decent box?
    Thanks heaps!
    Default Re: Auto to manual conversion
    There is a lot of info out there but here goes again
    Flywheel
    Clutch and pressure plate including bolts
    Spiggot bearing for the crankshaft
    Manual pedal box
    Clutch cylinder
    Slave cylinder and associated pipe work to go from the clutch m/cylinder to the slave/cyl
    re join wiring at gearbox to take out neutral safety switch
    You may also need a new rear gearbox mount as some models vary
    You will also need to enlarge the hole in the floor for the gear lever as it sits in a different spot.
    You will also need a rubber boot to cover the hole where the lever pokes thru.
    You will also need to look at changing your console.
    And probably a few thing I have missed.
    It is easily done in a day if you have everything
    Cheers Dave
    Cheers Dave
    1977 RA28
    1972 TA22
    1984 Supra
    I haven't done a TA22, but I did recently do my RA28. One thing Dave missed is the engine backing plate has two inspection holes for the Auto. Not much of an issue, and no biggie if you leave them there, but for that factory look, you might want to consider it.
    Also, specific to the TA22 is that you need the manual tailshaft (not required in the RA series as they are the same), and there is a small metal bracket which holds your clutch fixed line out from the car's body where it joins the flexible line.
    The wiring to the gearbox is easy, the auto has 2 feeds, one for reverse and the other for neutral. The neutral gets looped back on itself, and the reverse is two wires, which have standard bullet fittings on the gearbox's switch.
    he has a TA23 not TA22
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    Ahh... good pickup. However due to the difference between the output shaft of the T50 and A30, the tailshaft issue remains the same. Just grab one from any RA23, RA28, RA40 or manual RA60/65. The rest of what I posted need not be changed. Dave is correct that the rear engine mount is different, and unfortunately you are going to be purchasing the less common item, so it may set you back an extra 10 squid.
    Jan 2009
    thanks for the info. wishing i had bought a manual to start with but it doesn't seem too much hassle to change her over. will drive the auto until she i dead and do a weekend swap. cheers.
    Banned Backyard Mechanic Scoobzd's Avatar
    Apr 2007
    Wink Re: Auto to manual conversion
    And who has EVERYTHING needed to do this?
    We do
    Well, u might want to put in a shiny new clutch/master & slave cyl (have good s/h ones here)
    but for all the bits to convert just PM me !
    Ferny in Brisbane
    Jan 2009
    sweet. can you give me an idea of a price for the manual console to fit the ta23? thanks for the help scoobzd
  1. Ae71 Auto to Manual Conversion
    By gz10 soarer in forum Engine & Driveline Conversions
    Last Post: 25-11-2007, 11:50 PM
  2. MA70 --> JZA70 Conversion
  3. difficulty Manual conversion in late model chaser or aristo
    By 73ta22 in forum Tech and Conversions
    Last Post: 25-07-2006, 03:33 PM
  4. jzz30 auto to manual conversion
    By RIPSIP in forum Engine & Driveline Conversions
    Last Post: 08-06-2006, 07:08 PM
  5. Ma61 auto to manual conversion
    By Mattrt142 in forum Tech and Conversions
    Last Post: 22-02-2006, 08:13 PM
