do u have to tune this airflow meter into the 7mgte or just plug it it and it will run.?
DA-12-NV
If in doubt power out
same reason why a Gen 2 3SGTE AFM works on a S/T 20V 4AGE![]()
ok bought the airflow meter because the other was stuffed. plugged the v8 airflow meter in and the engine keeps stalling...the problem as the old airflow meter...anyone know what this could be?
DA-12-NV
Do you have the adjustment screw on the 1UZ AFM? Is it open or closed?
What codes is the 7m's computer spitting out?
RA23 - Twincharged
JZZ20 - Daily
no adjustment screw its a standard v8 one...but it is fully closed from standard...i have no dash light to no what the codes are...its on a mk2 corona how can i set that up to check!
DA-12-NV
Hook up the check engine light then bridge the connectors on the diagnostics port.
RA23 - Twincharged
JZZ20 - Daily
oh ok. thank you..
when i plugged the air flow meter in it was not placed into the turbo from pip[e it was only plugged into the airflow meter plug. does that affect anything?
DA-12-NV
can you say that in a way I can understand please?
RA23 - Twincharged
JZZ20 - Daily
Hi mate, you'll need different injectors or you'll be walking a fine line as far as leaning the engine out. A 7M doesn't need any more encouragement to go 'bang'
so the engine was not drawring air through the new AFM? you just connected it and left it sitting there in the engine bay?Originally Posted by da12nv
that would affect everything
ok put it in properly and it still ran shit...looked at the oxy sensor and there was a wire disconnected connected that and now the car runs perfect....dont kno for how long lol
DA-12-NV
This has made my night!Originally Posted by mattysshop
Dude, the air flow meter measures how much air is getting into your engine. If all the air getting into your engine doesn't flow through it, then things will be all sorts of bad.
lol ok now i know
DA-12-NV
