Results 1 to 14 of 14
Thread: Old Celica Differentials Diagrams (6.38, 6.7, 7.5inch + LSDs)
    Default 1st Gen Celica Differentials Diagrams (6.38, 6.7, 7.5inch + LSDs)
    I'm on fire tonight.
    This one's for you Norbie....
    Along the lines of my "transmissions" thread, here is a similar one, but for the differentials that graced the Celica (and maybe other models) in the early to mid 70s.
    Again, I made the images large to make the details more clear.
    Rear Axle Housing
    6.38inch Differential (S Series)
    6.7inch Differential (T Series)
    6.7inch LSD (T Series LSD)
    7.5inch Differential (F Series)
    7.5inch LSD (F Series LSD)
    seeyuzz
    river
    Melbourne Victoria
    Default Re: Old Celica Differentials Diagrams (6.38, 6.7, 7.5inch + LSDs)
    ah river the 6.38 diff was used for the t series motor or ET celica and also for the te27 levin with 2tg motor .and Tseries in the celica ta22,27,23 and also the the Fseries in the 18rg models RA 21, 23,25,28,and 35 celicas
    Quote Originally Posted by Celica RA45
    Thanks. That's good info. +rep for you sunshine.
    Do you know if the 6.38inch diff is a T Series diff? I'm not sure and maybe you can help out here.
    seeyuzz
    river
    New Zealand
    6.38 inch is S Series, also commonly mistaken for LSD when looking at the head as you can't easily see the spider gears. 4 pinion I believe.
    Callum
    Thanks for that. +rep for you too pal.
    seeyuzz
    river
    Not a patch on a Backyard Mechanic
    WA (Perth)
    Correct me if I am wrong, but I believe the 6.38inch diff was a 'D' series, not an 'S' series...
    It was this was on the build plate of the 1971 Celica my Dad used to own.
    RA23
    1G-GZE
    New Zealand
    The D series is different again, much closer to the T series in sizing at 6.62 inch. The heads MAY be interchangeable with the T series similar to the B-X-U code diffs if used with matching axles but have not personally confirmed just heard rumours.
    Callum
    Carterton
    D and T series diff heads are interchangeable. Swapped a T for the original D series into my 71 TA22 about 80,000 miles ago with no problems since.
    Mike
    71 TA22
    My Car
    You've done it again River, nice work champ.
    With your permission I'd like to link these images to the Toyota Axle Database. That OK?
    Go for it sunshine, knock yourself out
    seeyuzz
    river
    tasmania
    so are the diff housings for drums the same for disc rears as well?
    river is awesome! REP+++
    beer me!
    Melbourne Victoria
    trd parts book lists 5.6 inch is kp series starlet also 6.0 inch is the same for kp702 series
    the 6.38 is for TE series so te27 levin . .6.7 is for ta ae and st series as well .7.1 series is for mx series cressidas
    altezza and ra23 gt celicas all had 7.5 series
    8.0 inch were MZ20 and jx00 0 models and vn and js40 series and last were 8.7 inches is the ja80 series supra
    Alrighty then.... fixed up the broken image links in this thread.
    If you find any other pics of mine missing please PM me and I'll get it sorted. I know there's a few for the 2T-G engine which I'll probably do in the net day or so.
    seeyuzz
    river
    Photographer and Backyard Mechanic Rinmax's Avatar
    River you are more useful than a swiss army knife. If I ever make it up to Sydney, damn I'm gonna give you a big bear hug.
    "It's an ingenious solution to a problem that should never have existed in the first place." - JM
    "A Ferrari is a scaled down version of god while a Porsche is a Beetle with mustard up its bottom." - JC
