Results 1 to 5 of 5
Thread: 1ggte Distributor Wiring Question
    SignWriter Grease Monkey MZ20's Avatar
    Default 1ggte Distributor Wiring Question
    Hello,
    I'm wiring up a [IMG]file:///C:/Users/NEWUSE%7E1/AppData/Local/Temp/moz-screenshot.jpg[/IMG]1ggte with a wolf3d ECU. Anyone done this before?
    Ignition wiring is painfull...... anyone know the wiring for the distributor?
    I have the 1ggte wiring but I dont know if it is for the gen3.
    Glen
    [IMG]file:///C:/Users/NEWUSE%7E1/AppData/Local/Temp/moz-screenshot-1.jpg[/IMG]
    Default Re: 1ggte Distributor Wiring Question
    THe distributor has four wires out of it, I think I have the wiring diagram at home.
    Basically it's a case of, 1 is 12+, 1 is Home trigger, 1 is 180degree trigger and the other is the multi-tooth trigger.
    The wolf3d can plug into all of them.
    Facebook | LinkedIn
    Thanks for your help.
    So one is 12V ? I dont have that in !
    I thought the wiring was
    1 is 24 tooth trigger
    2 at sync trigger (180 deg out)
    1 is ground
    The wolf3d will pickup the signal if I pull out the dissy and spin it by hand. The problem is that at cranking speed the ecu wont pickup the signal. Only at about 1000rpm does it work!
    Do you think that I have a faulty dissy ?
    Glen
    0402727834 Grease Monkey turbo ke20's Avatar
    DO NOT connect 12v to the dissy.
    toyota dissys run a reluctor sensor and do not need 12v
    they have a ground supply and 3 sensors.
    the 24 tooth wheel goes to the wolf trigger.
    and one of the sensors on the top wheel go to the home wire to the wolf
    so in the wolf trigger harness you should have a 4 wire sheilded harness
    12v
    ground
    trigger
    home
    PROWIRE PERFORMANCE WIRING
    Specialising in:
    -Haltech
    -Full Rewires
    -Engine conversions
    -Custom Air Con. Installations
    -Drag, circuit & show car wiring
    Justin Moore
    0402 727 834
    http://www.facebook.com/profile.php?...88667244568569
    Jun 2009
    Hello, (i've now got my own account hence jazz9 not mz20)
    Thanks for the help so far. I have the car started, but not running well. It seems to show on the wolf3d as 750-800 cranking rpm and at idle (not very good idle) 4000-5000rpm.
    I only have the hand controller and I think it is setup for a CAS, I cant find any settings to change the teeth per rotation. I have the home trigger and the 24 thooth trigger showing up on the wolf.
    Anyone got any ideas??
    Thanks.
    Glen
  1. RA28 with 1GGTE, need some advice of the o so wise ones!
    By MIN728 in forum Engine & Driveline Conversions
    Last Post: 14-05-2008, 07:08 AM
  2. RA65 22RE Bellhousing vs 1GGTE
    Last Post: 18-08-2006, 05:58 PM
