Page 1 of 5 123 ... LastLast
Results 1 to 15 of 63
Thread: TA22: Tie Rod ends/Ball Joints, etc - OEM vs After Market
    Exclamation TA22: Tie Rod ends/Ball Joints, etc - OEM vs After Market
    I need to replace all the ball joints and tie rod ends in the front end and would like to know if it's worth trying to find an aftermarket option, or just replace with OEM items?
    Thanks
    Texas Hold'em Junky Backyard Mechanic fade-e's Avatar
    Default Re: TA22: Tie Rod ends/Ball Joints, etc - OEM vs After Market
    i installed powermax ones with no issues
    Thanks. Looks like there is not much talk regarding this gear so i can assume that owners must just replace with factory or similar (whats available) parts.
    How ever i did see some nice gear on Techno Toy Tuning (http://www.technotoytuning.com/produ...hp?vehicleid=1) and they said that they stock most parts they do for the AE86 for the TA22 (or early model Celica's). So i looked at the web site and saw the Lower Control Arms and larger Outer Tie Rod ends and thought it was great stuff.
    Made me wander if anyone locally also produced similar gear.
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    I'v just ordered all new steering parts for my ma45 from pedders. They also have listings for all early model celicas.
    I got the following:
    Balljoints
    inner and outer tie rod ends
    Pitman arm
    Idler arm and bush
    Retail price was approx $380
    1994 GZX90 Mark II 1GZ-FE V12
    i just got the front tension/toe rods from there as well as RCAs
    havent fitted them but dont see any issues
    as for the control arms, i am not sure on the law for adjustable control arms so you might want ot check that first unless of course the car will be track only
    Toyota no longer do them. I was going to weight up good enough verses WILD.
    I'll call Pedders tomorrow. A friend recommended Tripple S (or SSS, i don't know) as i can't locate them, but they run out from Japan.
    APJS have some as well and i'm waiting on an email. They seemed to have bumped up their prices since last year on a few items, so i'll tread carefully.
    The old One Backyard Mechanic
    Quote Originally Posted by hks7mgt View Post
    Thanks
    Difficult to come up with a straight forward answer to this.
    A consistent will be OEM. You can assume reasonable quality but the price may be high.
    With the after market stuff you are never sure what you are getting and price is not always a guide. I have had after market ball joints and tie rod ends fail after several years. Used to be able to rely on the quality from Repco but not so sure these days.
    Triptec's advice to source from a suspension specialist is most likely the best approach as they would be in the best position to know what is good and what is not. Its where I tend to buy from. You might also like to put the OEM v Aftermarket question to them.
    Craig
    Traditionalist Domestic Engineer parrot's Avatar
    I had a bad accident on a straight freeway once after an aftermarket tierod end failed. Essentially it bent after I hit some standing water which resulted in the car spinning off the road backwards.
    Problem of course is that OEM is barely available. And in my case (KE15) so is aftermarket. Virtually everything is obsolete, so you have to try and hunt stuff down NOS.
    Another option is to simply replace the boot, if the actual joint condition is still OK. I came across an Australian catalogue on the net somewhere that lists a whole range of replacement boots for tierods and balljoints. Apparently they are available from suspension shops and possibly repco.
    Cam mountain I feel different from the ordinary
    SA suspension centre in Pooraka are pretty good for getting suspension parts (unless you live way dwon south, then it will be a bit of a hike ). They are on Ween road. I never brought any parts for my Celica from when I had it, but there website says they stock hard to find bits.
    I had some powermax ones one my RA23, but sold the car after a couple of years, so I can't really say anything about longevity
    Oh, almost forgot www.sasuspension.com.au
    Quote Originally Posted by parrot View Post
    Gee i can't be too carefull after all. T3 had the outer tie rod end with a 5/8in ball joint on it. They do need your steering knuckle though to match the hole and it comes with a 'tube' too (as Toyota refered them as).
    Can i ask a general question on the matter? Are both the 'Tubes' supposed to be straight? The left hand side Tube between the inner and outer tie rods on my car has a bend in it and i'm thinking its there cause i've been hitting it for days on end it before i gave up and deceided to take out the entire drag link out in one piece with tie rods in place.
    Quote Originally Posted by Lachie View Post
    SA suspension centre in Pooraka are pretty good for getting suspension parts www.sasuspension.com.au
    Thanks Lachie. They're not too far from where i am so i'll call them tomorrow.
    I could drop off the drag link copmplete with tie rod ends and the control arms and get them to do all the hard work. I'll have to bring it back around to get the alignment donet thou, that's all.
    RA23 + 3SGE Beams Backyard Mechanic Major Clod's Avatar
    I'll call Pedders tomorrow. A friend recommended Tripple S (or SSS, i don't know) as i can't locate them, but they run out from Japan..
    I think what you may be after is a brand called 555. This was the only brand I could find a new idler arm for my ra23 through.
    1976 RA23 Celica - 3SGE Blacktop Beams Powered!
    1994 KZN130 Surf - Daily 3ltr Turbo Diesel Goodness!
    Update. There are a few places in Adelaide that sell Tie Rod Ends and Ball joints for the TA22.
    - SA Suspension - Brand: 'Road Safe' (on the shelf)
    - AJPS - Brand: 'Transteer' (no longer do the PowerMax)
    - Kent Engineering - Didn't catch the brand name, but they are confident about availablity of parts. Have heard great stuff about this place actually!
    All the above are interested in fitting the parts as well.
    aftermarket parts arent that hard to find!!
    three 5 (or 555) stock parts for TA22, as do powermax.
    Both are readily available from any decent parts shop!!
    PROBLEM SOLVED.
    the 555 is good stuff, japanese made too. It has a substantial cost premium over the chinese stuff though.
  1. TA22 + rack and pinion
    By "Z" UTE in forum Tech and Conversions
    Last Post: 19-05-2017, 12:02 PM
  2. strut brace for a TA22
    By ca_celica in forum Tech and Conversions
    Last Post: 11-04-2014, 11:55 AM
  3. Ta22 Idler Arm bushes
    By ThaNav in forum Tech and Conversions
    Last Post: 31-01-2009, 01:05 PM
