Results 1 to 15 of 17
Thread: 2jz-gte Oil Pressure Specs
    Forum Sponsor Automotive Encyclopaedia dori dori's Avatar
    Default 2jz-gte Oil Pressure Specs
    Hi guys, we got my VVTi 2JZ-GTE running on Friday night and it runs like an absolute gem.
    I have a question regarding oil pressure as my oil pressure gauge was reading 7 - 8bar at idle when cold.
    This seems a bit high to me and after reading Giantomato's post in Southo's oil leak thread i'm not sure what it should be.
    Oil is 10-40.
    I also spoke to Shane 'Gasman' 1JZ 747 and his 1JZ runs up to 100psi.
    Default Re: 2jz-gte Oil Pressure Specs
    8 bar is well high
    my 7m runs from 57 to 71psi when cold.
    I'd check with and search supraforums.com and .com.au to see if they can you.
    Cheers Glen, posted on Supraforums also.
    Anyone else?
    Quote Originally Posted by dori dori
    ....... and after reading Giantomato's post in Southo's oil leak thread i'm not sure what it should be.
    It should be what I posted at operating temperature. When cold I see very high pressures too.
    Thanks Giantomato, what pressure do you see when cold?
    It dropped to 6bar once it had been running for a little bit but still, it seems high.
    Could the pressure releif valve be stuck shut?
    and what a privelege it was for you to talk to me.
    mine idles any where between 70 and 100 psi, whats wierd is the pressure doesnt rise very much with revs, ie it might rise 5 psi.
    though if i have under filled it it will go backwards under load a lot more than 5psi.
    weird
    8.3 et PB 169 MPH PB
    Quote Originally Posted by 1JZ.747
    Spoken like a true blow ass.
    I have since swapped my oil pressure gauge with a known good one and it still reads 8bar.
    About the only other thing that could potentially be an issue is the oil filter i am using. Seeing as i have fitted the sandwich block under the oil filter its added an inch or so lenght which made the Toyota filter foul on the chassis rail. So i searched around for somthing a bit shorter in length and have used a Valvoline V033 filter off a Mazda / Subaru
    It too has the pressure relif valve inside just like the Toyota one. Could the smaller filter be causing the pressure buildup?
    Cheers guys
    I see over 100 psi when cold. Didn't I put all of this in the other thread? Why another thread about this within a month?
    Thanks Gianttomato, i checked with a mate who works at Lexus and he confirmed the 2JZ-GE runs 7psi at idle and 45psi at 3000rpm.
    Is it safe to asume the turbo engine would run higher oil pressure to keep the turbos fed all the time? Also a bit higher for the VVT-i?????
    I am going to replace the pressure relif valve and hopefully all should be good.
    Thanks for the help guys.
    7 psi and you have 8 bar
    wowzers
    7psi at idle is stupid low. Say hello to delamination of bearings, if not complete seizure.
    Thats what the book says.
    Also its amazing how much missinformation is in this industry. Everyone i spoke to has a different answer, and i spoke to alot of people.
    The best bit is when i tell them how much oil pressure it has they shit, thats heaps. Then i ask them what it should be they say i don't know.
    8 bar = 116.03019 pounds per square inch < bit of a difference.
    My IPRA car runs 70psi at idle, and around 85psi at WOT under load.
    Junior Member Backyard Mechanic manny's Avatar
    2JZ-GTE Workshop Manual Oil Pressure specs:-
    With engine at normal operating temperature, oil pressure
    should be at least 7.1 psi (.5 kg/cm  ) at idle and approximately 47-84
    psi (3.3-5.9 kg/cm  ) at 3000 RPM.
    GSE20 IS250 - daily
    Just heard from a friend who knows Nero from Titan Motorsport in the USA and he said that anything between 6 - 8bar is fine on 2JZ-GTEs. Aparently there race engines run upt to 10bar. Anymore and there is soemthing wrong.
    I'm inclined to go with Titan on this as they clearly know there 2JZ shitz.
  1. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
  2. Stuck oil pressure switch 3tg
    By MarioM in forum Tech and Conversions
    Last Post: 11-02-2006, 05:47 PM
  3. 1jz Oil Pressure
    By 1JZ.747 in forum Tech and Conversions
    Last Post: 23-01-2006, 04:32 PM
  4. 3SGTE oil pressure maybe low?
    Last Post: 12-01-2006, 04:40 PM
  5. engine pinging
    Last Post: 15-12-2005, 01:15 PM
