Results 1 to 15 of 16
Thread: advantages of using 1.3 radiator cap
    Jan 2009
    Indonesia
    Default advantages of using 1.3 radiator cap
    Hi...,
    I had just changed my radiator using aluminium radiator. Please tell me what would be the advantages if I use the 1.3 bar radiator cap ?
    If it has advantages, i might plan to change my 0.9 bar rad cap to the 1.3 bar cap.
    Can anybody out there please advice me on this matter ? Your advice really appreciated.
    Thanks.
    Default Re: advantages of using 1.3 radiator cap
    Higher pressure means a higher temp before boiling. Obviously tends to lose a bit less coolant at the track as well seeing it'll hold a higher pressure. Boiling point increase is the main purpose though.
    Aug 2009
    exactly... ^^
    nuff said haha
    Nov 2007
    Boiling coolant does not absorb transfer heat very well, so if your using your car on the track a radiator cap rated at 1.3 bar than 0.9 bar would be better, as your coolant is less likely to boil, removing heat more efficiently from the engine.
    Aug 2009
    coolant should never, EVER boil.... thats what ethelene glycols main purpose is, anti freeze anti boil
    having a cap rated at 0.9bar raises the standard boiling point of water to approx 120 degrees and the ethelene glycol stops it boiling
    if your coolant is boiling theres a leak in the system, ie head gasket, split tank or hose, either way the pressure is escaping someone
    Jan 2009
    Indonesia
    Quote Originally Posted by pandaah View Post
    Sorry for my poor english.
    So are you saying that using the 1.3 bar rad cap would definitely better than using the 0.9 bar rad cap ?? Kindly reply. Thanks.
    Yes, definitely
    Junior Member Backyard Mechanic Jaemus's Avatar
    Of course, seing as how the pressure will be increased, there is more chance of a failure such as a hose blowing off; if your cooling system is about to fail in such a way this will certainly provoke it to do so.
    1992 MR2 GT turbo
    2009 Lexus IS-F
    Built Australia's first V6 MR2 >> Winner: "I'd Drive It" award - Toyfest '07
    Aug 2009
    if your not running high boost or your motor has a good condition cooling system then it probly wont even make a noticable difference till you take it to the track and thrash it...
    Nov 2007
    Do you have a water temp gauge?
    Take it to the track and see how you go, then you can make decisions to whether you need to change rad caps etc.
    Jan 2009
    Indonesia
    yes i'm only running 1.1bar. this is still low boost right ?? yes i do hv water temp gauge, but still not yet installed yet ? why ?? which brand of rad cap would you suggest for toyta celica gt4 st185 ? thanks.
    Altia ER34 GTT Domestic Engineer JetspeedCamry's Avatar
    Why do they not put 1.3bar caps with fittings and hoses to suit the higher pressure on in the first place? Does it have any disadvantages or problems for a road going car?
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    Quote Originally Posted by davidleonardi View Post
    I used the TRD cap on mine but there are others around.
    Aug 2009
    cusco, trd, all those are very good brands, i think you should just install it.. you wont have any problems and least you car will be handle the head when you decide to put your foot down hard
    just make sure all your hoses are in good condition.
    any hoses getting a bit old are likely to burst when you switch the car off and its hot and holding more pressure than normal.
    the downside is obviously more pressure before it overflows, which is also a up-side in some ways. just something to be aware of
  1. Advantages of barrel i/c
    By Dimmy in forum Tech and Conversions
    Last Post: 30-09-2008, 10:19 PM
  2. 1uz ITB's theory & advantages
    By Crambo in forum Engine & Driveline Conversions
    Last Post: 11-01-2008, 12:59 PM
  3. Advantages of a step in the exhaust flange
    Last Post: 01-09-2007, 09:25 AM
