Map sensors regardless of the map range usually output a 0-5V signal. (This is a gross generalisation as in practice there is some deadband at each end for error generation).
i.e.
1 Bar Map sensor = 0V full vaccuum, 5V 1Bar
2 Bar Map sensor = 0V Full vaccuum, 5V 2Bar
etc. So basically no you can't use a boosted map sensor.
A one bar map would most likely not even register a positive pressure and if it did the ecu would likely not be tuned for it anyway.
			 Naturally Aspirated MAP sensors + boost
