just grab some MX62 power window regulators and use the motor part on your regulator. i used MX62 motors on my RA40....it worked fine up until now.....needs a little TLC.
you do have to cut both regulators at the same point to make a hybrid unit....if the RA23/28 regulator s are the same as RA40 ones then its do-able. i suppose as long as the gears have the same pitch and height then it should work![]()
