Results 1 to 4 of 4
Thread: Info Request: AE86 balljoint & tie rod Taper?
    teq Grease Monkey
    California
    Default Info Request: AE86 balljoint & tie rod Taper?
    Well, after spending several hours I'm giving up on searching. Anyone know what the Taper (in degrees preferably) for the AE86's front lower ball joint, and tie rod ends?
    AND if possible, sources to buy tapered reamers in the right size from?
    Thanks,
    Andrew
    perth
    Default Re: Info Request: AE86 balljoint & tie rod Taper?
    i dont have any info on the taper size, but ive had my machine shop, machine the correct taper for my ball joints into my steering arms. (sigma ball joint to *a6* steering arms.)
    teq Grease Monkey
    California
    Yeah, problem is. I don't want to pay a machine shop if I'm experimenting with different lengths and offsets (to change ackerman). I also have access to a nice drill press, and a milling machine. So it'd be cheaper for me to buy my own reamer and do it up myself.
    Still on the lookout, anyone else wanna chime in?
    Andrew
    User Conversion King
    NWA
    you can always work it out.
    measure the length at one end, then the other. use half the difference and the length along with trig to get an angle.
    a good set of vernier calipers will get you very close
    hello
  1. Replies: 13
    Last Post: 12-08-2007, 05:00 PM
  2. 4AC AE86 conveted to 4AGE, 4AGZE and 4AGE 20V
    By wombat in forum Engine & Driveline Conversions
    Last Post: 18-04-2007, 10:43 PM
  3. 4AGZE to 4AGTE in AE86 Info needed
    Last Post: 17-06-2006, 12:15 PM
  4. aust AE86 standard springs info within
    By roadsailing in forum Tech and Conversions
    Last Post: 17-01-2006, 10:50 PM
