Results 1 to 14 of 14
Thread: Excessive blowby caused by overfilling engine oil.
    Default Excessive blowby caused by overfilling engine oil.
    So i had a pretty bad day today, i was trying to get the oil level in the car right yesterday but because i only reconditioned the engine about a week ago the oil was so clean i couldnt tell if i was over or not, it seemed to run fine anyway. But today it just conked out, there was heaps of pressure in the crankcase, and eventually the crankcase was letting out air just like the exhaust was. Fkn hell hey.... :'(
    Anyway my question is, would the overfilling of the oil cause this blowby? There are new rings and new gaskets and everything. Or did i just stuff something up when putting it together.
    Any help is greatly appreciated.
    yes, i own a car, it has four wheels and an engine. and in the end, isn't that what really matters
    Apr 2007
    Default Re: Excessive blowby caused by overfilling engine oil.
    How much over full is it ? if its only a litre or two its not ideal but would not be causing your problems but if its overfull by many litres it could cause some problems but it would have to be way way over ..
    Sounds like youve got a different problem
    Got a compression tester?
    firstly your crankcase shouldn't build up pressure like that. Next is have you figured out why it stopped? Have you had it running since then? What engine etc etc
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    PCV working and plumbed up to the intake?
    its a ae82 twinky, 4age, the pvc is plummed to the intake and i did have it running but then it conked out again 10 mins later.
    Nov 2007
    you know that if you fill it up even by a few litres the crank can hit the oil cause it to froth, from this the oil pump cant pick up froth = no oil to vital engine components!
    but it should have lubed the cylinders walls(thinking of piston ring wear), so is it pushing oil into the inlet via PCV? That could cause it not to run.
    Did it blow smoke before stopping?
    As said before do a compression test, also look at the colour of the plugs
    next time check specs on fluid quantities and fill to that give or take 0.5L
    South Australia- Where the RIGHT Lane is the NEW LEFT LANE!!! *@#$&
    1974 280SEL Mercedes Benz
    1979 RA40 Sillycar
    1991 Subaru Liberty Heritage
    2010 Great Wall X240
    Nov 2007
    also when the oil is clean on a dip stick. get light to reflect on the oil on the check area, you should be able to see a difference in reflection between the dip stick and the oil.
    1979 RA40 Sillycar
    Hooligans Holiday Grease Monkey kickstartRA28's Avatar
    Apr 2009
    Also give it time to run in the rings will need a little while to bed in properly.
    Jul 2009
    Jul 2009
    even though the pcv is hooked up is it working correctly, they do fail easily
    1985 RT142, 1GGTE,.now with t67-25g
    2009 Ford Fiesta LX
    1970 Ford Cortina MK2 440
    how is it that you can reco an engine but can not work out the oil level?
    is it outside the car or you have no dipstick or something?
    Nov 2007
    After reading that article DropBear posted.
    I have thought the same.
    I had 2 mates that bought motorbikes at the same time, same type of bike
    one of the blokes run it in as per directions. the other fella said stuff it and gave it what for from the start.
    the bike that got thrashed from day one ate the ran in bike easy. I think the thrashed bike out lasted the other one too.
    I have heard of this happening before.
    sorry about the hi jack
    1979 RA40 Sillycar
    Jul 2009
    i agree ra40rob most people baby the engines but they need to be driven at 80% atleast straight up
    the whole running it in thing is from a bygone era.
    2009 Ford Fiesta LX
    Last Post: 12-07-2019, 06:11 PM
  2. Sams MA61 7MGTE Conversion Guide
    Last Post: 08-07-2015, 12:12 AM
  3. Toyota R Engine History
  4. MA70 --> JZA70 Conversion
