On most toyota engines from memory the engine # is stamped on the block on fwds i am pretty sure if you are staring at motor from the front of the car on the right hand side just beneath the manifold and about an inch below wehre the head ends. check both sides as my memory is from inspecting damaged vehicles at an auction yard 5 + years ago and it could be fuel or exhaust side but thats where it was on echo's corolla's camry's etc (which sure seemed to get smashed alot)
I assume you are looking to see if its the original motor or not eg if it matched VIN plate and rego papers. see how u go but as i said on block just under manifolds maybe an inch below the head gasket usually
