Results 1 to 15 of 20
Thread: Second Air Con for Ute Canopy.
    GT4 Freak, and Conversion King Squid's Avatar
    Default Second Air Con for Ute Canopy.
    Hi -
    This question is for the Ute - RN85R with a canopy.
    We have two large dogs, hence the purchase of the ute with canopy. But we noticed that in the hotter months, the rear gets bloody hot when driving, even with all windows and open.
    Is it feasible to run a second element on the one AC system to chill the back.
    I have thought about using a swampy or something, but having to add ice constantly is kind of retarded. I have also looked at 12v Air conditioners for caravans etc, but they aren't cheap!
    Other options I have considered, and still haven't ruled out:
    Re directing one of the interior vents via some tubing and fans to the back.
    Putting a vent (possibly with fan) between the canopy and the car.
    ST185 GrpA #116
    ST165 GT4 Project Car - Soon with v6 goodness.
    The glass is neither half empty nor half full, rather the glass is twice as big as it needs to be.
    Feb 2009
    Default Re: Second Air Con for Ute Canopy.
    you could add a simple knee freeze unit to your existing a/c.This would require additional lines and so on.Your compressor then may not have the capacity to run it, and with most hilux's the condensor will be far too small.
    Adding a second aircon in (off the existing one) is never going to be an easier solution.
    You can purchase all the gear from a Crown or Celsior (which have a rear aircon/fridge), and even if you assume your AC compressor is up to the task, I doubt the condensor will be.
    I know my old 60 series condensor was crap (too small due to no room), so I doubt the 80 series is much better (could be wrong).
    User Conversion King
    NWA
    i think the simpleist solution at the end of the day is to improve outside airflow.
    ive seen the hilux's that they have the drug dogs in and they have 2 spinning whirlybird type things.
    otherwise there is venturi type vents like this http://www.whiteheather.co.nz/rv-par...re.php?id=VTEV
    adding another evaporator to the AC system will compromise its reliability and performance
    hello
    Having a look at the car last night - my current preferred option is to hijack one of the AC vents, run some insulated 2 inch piping to a box inside the canopy. Will add a 12v fan to the box and she should be right...
    ST185 GrpA #116
    vic
    Why not just a sliding back window , then you can talk to them as well
    Dave
    Quote Originally Posted by cambelt View Post
    Dave
    Canopy doesn't seal against the ute, but that could be a good idea... might investigate.
    ST185 GrpA #116
    Not trying to be a Carport Converter
    Jan 2009
    The site ambo has a similar setup. Just a conertina heavy duty rubber joiner between the cab and the pan.
    Put in a couple of nice NACA ducts in the side windows and a whirlybird on top and you should get decent airflow through without needing to add refrig:
    Junior Member 1st year Apprentice Mr89Cressida's Avatar
    Mar 2009
    New South Wales
    you can add another compressor and condensor to the engine bay and a inside canopy evaporator and fan controller, but that wont be cheap, the only other way as mentioned is a evaporator and run everything of the rest of the car some curiours use this method when they deliver food just to keep it kinda chilled wont be very cold but not boiling hot...
    it just comes down to how much money you are willing to spend...
    GL
    I Dont Care How Fast It Is There Is No Joy In A Diesel...
    MX83 7M-GE Turbo 280Kw@rw 7psi
    If Its Broken Use A Cable Tie...
    Subaru Legacy B4 Twin Turbo
    Nov 2007
    I used to drive a refigerated delivery hilux. like the ^^^^^above post mentions
    the refrigerater system run off the car system piggy back style.
    made the cabs aircon crap, only good on cool days!!
    South Australia- Where the RIGHT Lane is the NEW LEFT LANE!!! *@#$&
    1974 280SEL Mercedes Benz
    1979 RA40 Sillycar
    1991 Subaru Liberty Heritage
    2010 Great Wall X240
    are there electrically-driven a/c compressors for cars? they use electric motors for power-steer and brake-servo-assist in some rear/mid-engined cars - tho i'd guess that an a/c compressor would require more power than a vacuum pump.
    I like senn 's idea of a bit of flexible ducting (perhaps wit fan) between the tub and the body - just need to find such an item.
    Given up on the idea of refridge, whilst it a nice idea it will proove too costly
    chuckster - yes there are, but they start at more than the value of the car.
    As for doing it by airflow - the airflow is already good, but on a day like today, with the air temp at 40degrees, the temp inside the canopy sits well over 50 degrees, and that is far too hot for a dog. Means I can't take the dogs to the river on a day like today, which is the perfect time to take dogs to the river.
    ST185 GrpA #116
    NWA
    take the canopy off
    hello
    Then they get burnt...
    If you decide to aircon it, put some serious amount of insulation, as the 3mm thick fibreglass will be doing SFA.
  1. Brahma Canopy - 1992 Hilux - What gas struts.
    By Squid in forum Tech and Conversions
    Last Post: 17-08-2009, 12:51 PM
