semi-sequential?
http://www.m-techautomotive.co.uk/ec...c_glossary.htm
ie, as you said waste spark for injectionSemi-Sequential Fuel Injection - Semi-Sequential means that 2 or more cylinder's injectors are triggered at the same time, but only 1 time during the engine's cycle. This requires the ECU to be synched with the engine's cycle. Typically injection timing is retarded from the optimum timing point for full sequential by an angle which is equal to 1/2 the angle between 2 cylinders in crankshaft degrees. Semi-sequential allows optimization of injection timing which typically leads to increases in midrange torque and a reduction in fuel consumption for equivalent power compared which Batch fire.
the difference between batch fire and semi-seq is that the phasing of the semi-seq can be changed to different parts of the engine cycles..
whereas batch injection is basically semi-seq but with a fixed phasing you can't change
