ATTACH][/ATTACH]Where I started:
Focussed on the Rack positioning. Three positions need to be considered:
1. Distance behind the crossmember
2. Height in relation to the LCA inner pivot points
3. Length of the bar
Edit: just realised something after writting this post up. I'm working a bit backwards here. The positioning is relative to the LCA inner pivot points. I'll fill you in on the LCA inner pivotpoints in the next post. So you need to do the next post first, ie before this one.
After heaps of 1/2 scale drawings, I came up with this position for the Rack:
1. Distance:
The Rack is 85mm behind the Centre of the LCA bushes. Another way of saying this is 85mm behind the centre of the crossmember, looking laterally. So I'm guessing roughly a 20mm gap between crossmember and the rack. Hope that makes sense.
NOTE: I had a AE86 crossmember in my garage, and these had the rack about 115mm behind, not 85mm. I chose 85mm for a few reasons, one being it suited what I wanted for ackerman better, and secondly the KE20 steering knuckles (108mm modified) are considerably shorter than AE86 (132.5mm) and AE86 p/s ones (115, 120mmish- can't remember exactly. Also, this way it doesn't put too much strain on the KE20 knuckles and rack ends when turning with lots of lock.
2. Height:
The Rack is 6mm ABOVE the LCA inner pivot point. Saying that another way is the centre of the rack ends are 6mm higher from the ground than the centre of the LCA inner pivot points.
NOTE: AE86 racks are 7mm higher. So very similar. In my 1/2 scale drawings, this measurement seemed to make the biggest difference to any bump steer, so really try get this to within 1mm either side of 6mm.
3. Length:
Did 2 attempts. first one I shortened the rack by how much closer the LCA inner pivot points are in my design, but it didn't work. A lot of bump steer, possibly more than a standard AE86. But it was toe in on compression, not toe out. Yuck.
Fitted a spare rack bar I had (standard length) and brilliant! No bumpsteer at all in compression and the in the first 25mm of droop. Then slight toe out with more droop. (this is with 40mm RCA's).
NOTE: Without the 40mm RCA's it would still have no bump steer in compression at all, nor at least for the first 65mm in droop. But this isn't much good for roll centres, and understeer would result in hard cornering (due to tire scrub, not bump steer obviously). Besides, a bit of extra ackerman on the inside wheel in turns never hurt... check out the competitive IP cars like the front line escorts. The theory behind that is too much for this thread.
OVERALL NOTE ABOUT MY RACK POSTION: i mounted my rack and LCA inner pivot points rather low (because of the tall 3sge motor). The LCA inner pivot points are 15mm below the standard position in the KE25 Crossmember. They are also a lot further out, but I'll get to that later.
Below you can see the split lock collars. I had them facing backwards, so I could get the rack out without having to lift the motor. You might notice my crossmember is not very high. Alot has been cut out of the hieght so I could get the motor low. Obviously we put a lot of metal in that crossmember to strengthen it again.
