Results 1 to 3 of 3
Thread: 2jz-ge cam upgrade options?
    Default 2jz-ge cam upgrade options?
    Hi
    I have seen many cams available for the 2JZ- GTE, HKS and Crower etc. I know the exhaust cam is no use as it doesn't have a dizzy drive gear.
    Question is will a GTE intake cam fit in GE head? If so I can get an HKS or something similar. If I want the exhaust upgraded then I could have it ground by clive cams.
    Thanks ANdrew.
    Junior Member 1st year Apprentice 87lux's Avatar
    Mar 2008
    queensland
    Default Re: 2jz-ge cam upgrade options?
    maybe try someone like kelford cams they should be able to do a set of cams to suit a ge
    According to supraforums US. The various brands of GTE upgrade cams can be used on the intake side (HKS,TODA etc). In general they use a regrind on the exhaust to get a dizzy drive gear.
    It seems this is a common upgrade for the NA-T conversions.
    http://www.supraforums.com/forum/sho...d.php?t=579605
    By The Witzl in forum FAQ
  2. 1JZ > 2JZ Map Sensor Upgrade Myth Burried.
    By JZA70 R in forum Tech and Conversions
    Last Post: 14-11-2008, 09:45 AM
  3. KE70 upgrade options - request
    Last Post: 14-05-2008, 03:09 PM
  4. Front Strut upgrade for KE26
    By vkboy in forum Tech and Conversions
    Last Post: 31-12-2007, 04:10 PM
  5. Hoppers Stoppers brake upgrade vs Pug/Lux/Corona brake upgrade
    By ThaNav in forum Tech and Conversions
    Last Post: 04-10-2007, 01:31 PM
