Results 1 to 15 of 30
Thread: Alternator smoking when battery put back??
    Jun 2009
    Default Alternator smoking when battery put back??
    Today i connected the battery up and was gonna start it.. but as i put on the negitive terminal i heard ticking noises on the alternaator side.. THEN i saw smoke billowing out of the alternator?? white smoke.. smelt like cap gun caps lol..
    but why?? never had a prob before doing this.
    thanks guys
    90' GT-Four ST185 RC motor ST205 gearbox!
    New installs Ct20B and Rear Strut Brace!!
    Next to come;
    3SGE cams, Fidanza Adj Cams, WolfKatz fuel rail!!
    Default Re: WTF?? ALTERNATOR wtf
    Are you sure the big wire was connected to the alternator, and not just resting against it?
    Apr 2007
    Have you accidently swapped the Battery polarity ? ..
    Jun 2009
    Yeh i checked that the bat was the right way around.. and i had it connected like that before without any probs..
    i will check the big alternator wire tonight.. does this mean my alternator is screwed??
    Next to come;
    not necessarily but you may have blown a fuse fuses.
    I know nothing Grease Monkey damian's Avatar
    Feb 2010
    I would suggest once you let that magic smoke out, it no go anymore
    I had the same thing happen to me many years ago, and it was a result of me fitting too powerful a battery into a car. Donor battery was out of a modern 6 cyl (elec everything) Cressida, and put into an old 6cyl (electric nothing) Holden. I managed to fry the alternator before the fusable link blew.
    is firing on all eight. Carport Converter AndyTTR's Avatar
    Check that the fat alternator cable isn't touching any other metal part except the post its bolted to.
    Sometimes the plastic insulator piece breaks off and the cable will rotate and touch on something metal as you tighten it down.
    Hmmm smoke got out of the wires. All bad!
    Now - RA23-WRX
    Jun 2009
    hmmm well i looked at the big cable and its connected nice and tight. and the rubber boot around it is kinda cracked but i dont think too bad.. looked at the alternator fuse.. looks corroded.. ill have a look around at the wreckers..
    Damians point got me thinking.. i did recharge this battery a little while back.. but had it running after charging with no probs..
    still popping and smoking.
    Next to come;
    Quote Originally Posted by damian View Post
    that won't cause a problem
    Quote Originally Posted by Sam_Q View Post
    Agreed. 12V is 12V, and a battery will only supply as much current as is drawn by the system, even if it is capable of much more.
    Unless there is a fault, and the fuse doesn't do its job, then a large battery will do more damage than a small battery.
    Feb 2010
    I agree that in theory 12v is 12v, but in practice i fried a car (it was only a holden, so no great loss) and i definately did not have the polarity the wrong way round when hooking up. I was trying to jump start, but the cars were too far apart for the cables, so i swapped batteries. I had jump started the holden using the Cressida many times before with no problems (battery was on the way out, so a couple times a week), but this one morning, she fried, she fried!
    isn't that part of the reason when jump starting you don't go battery terminal to battery terminal, but rather put the negative onto a metal part of the donor car (preferably engine block)?
    maybe the car i was jump starting was used to bugger all power, and the fresh 12v spike killed it?
    dunno, but i know i killed it
    and the donor battery worked fine when put back into the Cressida.
    TRDcelica90 said he just connected up the battery, so I guess it was the same battery that was in it before, so my thoughts probably have no relevance then to this problem then? Just throwing ideas out there...
    Jun 2009
    yeh well i need all the help i can get.. its so strange never thought this was even possible lol.. just random. ive been disconnecting batteries to let all kinds of cars sit for ages. never had ANY prob let alone this crap..
    Next to come;
    Jun 2009
    Default Re: Alternator smoking when battery put back??
    do i have to chuck this alternator??
    Next to come;
