Results 1 to 15 of 29
Thread: Tuning transient throttle enrichment on aftermarket ECU
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    Default Tuning transient throttle enrichment on aftermarket ECU
    Can everyone share their experiences, tips etc?
    I've got a Haltech E11v2 on the Toyota 7MGTE, and am having trouble getting a lean spike out of the AFRs when you open the throttle very lightly (3-7% and hold it) on gearchanges and slowly revving the car up etc.
    Any ideas, and, would AFRs of 16-17:1 do any damage to the car if it is barely under load at all?
    Driving around and then nailing the throttle is fine, enriches properly and runs safe AFRs, just super lightl loads.
    Thanks all, want to hear your stories!
    Default Re: Tuning transient throttle enrichment on aftermarket ECU
    only a problem if it causes hesitation.
    on MS you can tune the enrichment on throttle movement in diffrent parts of the map to eliminate the hesitations, or, you can richen up those areas which are onyl ever used in the transition.
    but if it still smooth, the lean AFR will not usually cause issues
    I wouldnt worry about it.
    16:1 AFR at those small loads wont harm anything.
    Its mashing the pedal from light cruise where you need to really worry about lean AFRs and TPS-enrich settings.
    yup, and about tuning out stumbles on transition.. if it isn't stumbling (ie,lean or rich misfire).. all good.
    thanks guys good to know. i thought that was the case but would hate to blow something . will probably richen up a few bits too that won't get used otherwise
    Quote Originally Posted by RyleyMA61 View Post
    what kind of spike? ...for a split second or a sustained spike, if theres such a thing?
    A spike for a split second could be a missfire...
    No. I cruise and idle @ 16-17 AFR
    Todd
    JZA70|R / 12.45 @ 111 mph.
    yeah, it's not misfiring, just a split second spike when the initial rush of air comes in and the ecu is too slow (enrichment is done by % throttle / 10mS period- sucks the wang)
    there is a misfire at one point but i might just richen it up to counter it, fuckit. i'd rather it drive like a standard ecu car than get a wee bit better economy.
    thanks todd, read your tuning thread lots, good info, very inspiring.
    Thanks mate. Unfortunately you cant smooth out misfires with more fuel as it doesnt matter how much fuel you add, its not going to ignite. No ignition no burn no gas therefore the o2 sensor wont pick anything up except for a pocket of air which will read full lean.
    In regards to enrichment, are you sure the e11 is only correcting in 10ms increments? that doesnt sound right are you sure thats not the refresh rate of the reading in the software?
    Jun 2008
    Ryley, Sorry to hijack..
    -JZA70 R
    What trick do you use to Idle @ 16+ AFR??
    My bloody VG shits itself @ >12afr & it bugs me.. alot....
    -A
    I've found that modifying the injector timing allows the fuel to atomise better and let you run leaner at idle without it stumbling etc.
    basically get the engine idling at a steady rpm with a stable injection rate, then change the injection timing until the mixture is the richest. Then you mod the fuel map to take excess fuel out.
    no trick, every engine is different and how you've set it up will play a large role in how it behaves at different air fuel ratio's.
    i played with mixtures a lot while tuning, found the limits at all different points of load, rpm ect and it just so happens that it was happy to idle at 16:1. The car would start to stumble at > 16:5 and during cruise would surge.
    If you jump to 50 seconds in this vid, you can see and hear it idle at 16
    http://www.youtube.com/watch?v=fAdAfqzRD0A
    Todd
    Jun 2008
    -JZA70 R
    That sounds fantastic & rock solid too.
    I swear there must be something my car hates about the MT ecu... I had rock solid Idle on the 20 year old LINK unit... But not sure on the AFR back then.
    Cheers for the clip.
    -A
    I can get away with around 15:1 idle on the 1mz..
    Maybe we should start a tuning discussion thread as this is all pretty interesting stuff for those of us who like to tune own cars..
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    Aug 2009
    yeh that sounds like a good idea, as id let to get into it myself too as im sure many other people would..
    how are you guys tuning by yourself btw?.. obviously road testing but how are you starting off from base maps etc?, and what software and computers are you using....
    because pending my 1jz install in my z20 i may buy a certain computer if i know i can tune it myself..
    thanks guys
    Good idea, someone start a fuel/ignition tuning thread
    Im running a Microtech LT10s and Innovate Motorosports LC-1 WB02 kit.
    The MT ECU works, but its a piece of shit!
    I would never recommend anyone install one for street use. Is OK for a track/drag car though.
    If i were going to buy a new ECU, it would be a Wolf V4X or V500.
    Very very powerful ECU's and awesome PC/Laptop tuning software.
  1. 1G-GTE tech info/diagrams
    Last Post: 27-02-2016, 05:43 AM
  2. HELP: 1GGTE running slow, Error code 11.. what is it? *FIXED*
    By Jabtronic in forum Tech and Conversions
    Last Post: 31-01-2009, 02:05 PM
  3. Toyota diganostic error code, where can i find them?
    By MarkIIRx12 in forum Tech and Conversions
    Last Post: 19-03-2008, 01:42 PM
  4. 1jz Aftermarket Ecu
    By thommo in forum Tech and Conversions
    Last Post: 27-01-2006, 10:09 AM
