I also used a 1JZ-GE VVTI . Mine came from a 2001 Crown . Has ETCS with traction control and speed control in the engine ecu. Had 1 speed sensor on the auto . I went manual so I did not need speedo sensor. My wiring diagram shows no dedicated wire from ecu to speedo so I suspect it goes through the CAN bus. Wiring some tricky electronics from your existing speed sensor to your speedo sounds like the way to go
