Results 1 to 3 of 3
Thread: Crankcase Breather and PCV Valve
    Selangor
    Default Crankcase Breather and PCV Valve
    In the 4K engine, there's a crankcase breather port
    just in front of the PCV valve grommet, and behind
    the oil filler cap, connected by a short L-shaped hose
    to the air filter housing, where it opens up just behind
    the air filter.
    Is this crankcase breather an inlet system (drawing
    air from the air filter) or an outlet system (venting
    blowby from the crankcase to the air filter) ?
    Secondly, if I remove the PCV valve hose and plug
    it off, leaving the valve itself sticking on its grommet.
    would the valve still be able to ventilate some blowby
    gases into the open air (from the blowby pressure
    forcing the valve open) ?
    Default Re: Crankcase Breather and PCV Valve
    Normally the breather is both, an inlet and an exit.
    You should leave the PCV system as per the factory setup if possible.
    It is there to remove blowby gasses from the crankcase which pollutes the engine oil.
    When at idle, cruise and overrun the crankcase gas is pulled out via the PCV valve, and fresh air is pulled in via the breather.
    During acceleration, the PCV is closed, and gasses vent out the breather.
    Selangor
    Thanks for the info.
    I disconnected the PCV valve, as the engine is aging with
    loose piston rings and valve seals, so the excessive and
    dirty blowby tends to clog the valve pretty fast.
    You mean if the outlet side of the PCV valve is disconnected
    from the manifold hose and left there in its grommet, it would
    remain permanently closed, with no blowby gases coming out ?
