bottom end knock?
pull off sump and check rod bearings with pistons still in block.
replace if necessary but make sure clearances are correct.
could do mains, but will need to drop the crank, but that would make it easier to measure the journals.
unless you particularly want to change rings as well?
tbh, you could just hon with wet n dry, linish journals same way, throw it back together and it will keep going for a whilenot ideal, but if you do it right, then it would be fine
