Step 05:
Once the pulley is removed, you need to pull the bearing out.
Don't stuff around with pullers etc. Just put the pulley over the hole on the anvil or brake drum etc and put a socket on the bearing from the top.
Give it a few good whacks and it'll drop out.
I used a socket that fit into the bearing when placed upside down (bolt side of the socket facing up).
Give the pulley a good clean with degreaser etc and a soft brush.
Now grab the new bearing and use the old one as a drift to tap the new one in. Be sure to hit it in evenly all around the edges only so it doesn't skew and jam up (only hit the edges so as not to shock load the balls and dent the races in the bearing) .
Also, be sure to put the small ring back in the right way up too.
Step 06:
Ok, once the new bearing is in firmly to the bottom. Reinstall the pulley on the compressor.
Stick the circlip back on to retain the pulley.
Step 07:
Now we set the clearances for the clutch.
Reinstall the clutch and the washers and tighten the centre bolt (not too tight, just nip it up).
Set up your dial gauge so it is sitting on one of the three rivets on the clutch as shown below.
Activate the clutch with the 12V battery and measure the amount of movement on the SECOND activation (well NOT the first, the clutch has to seat properly first). Do the same for all three rivets and average the results.
You want the clearance to be between 0.35mm and 0.65mm, closer to 0.35mm is ideal to account for future wear.
If it's out of spec, mix and match your washers to get in that range. You may have to file down a thicker washer if you've got too big a clearance.
Keep replacing shims and measuring until it's right.
Step 08:
Now, if you are using a compressor from a Starlet, the electrical plugs are different. Carefully remove the Starlet wiring and replace them with the Sera gear.
Give the whole lot a clean, paying special attention to the rotation sensor. It's the solid metal sensor that's retained by an Allen screw. Make sure it's perfectly clean from all dirt and metal filings (it's slightly magnetic) before reinstalling it.
Now you're ready to reinstall the compressor and get the system recharged.
Enjoy a nice cold Air Con system.![]()
