Results 1 to 5 of 5
Thread: GT4 gearboxes factory lsd??
    Jan 2007
    queensland
    Default GT4 gearboxes factory lsd??
    hi all..
    sifting through the mass amounts of LSD options for these boxes... and the awsome write up from Terry on the E series...
    do any of the GT4's come with factory LSD in the front? not the transfer case section that bolts on.. but the 'conventional' 2wd diff part..
    Mat.
    Default Re: GT4 gearboxes factory lsd??
    From http://www.toymods.org.au/forums/sho...nt#post1190822 and several afterwards:
    All GT4s have a viscous LSD centre diff.
    All GT4s have a open front diff.
    All ADM 185's and all 205's have a torsen LSD rear diff.
    there was some rallye special (jdm only) 185s that had an lsd front too i believe.
    That would be *very* special, ie only a hundred or so made for competition.
    I know that TTE made a front LSD diff for them, but its almost impossible to find one, and then VERY expensive.
    Stumpy raised a few related valid points:
    Quote Originally Posted by stumpygt4 View Post
    I know of someone over here in the West that had made a 185 box with a LDS out of a MR2, It took a little bit of engineering. If you had a clutch type front LDS it would be a bit of a bitch to drive.
    Or you could buy a box from Neil Bates out of a Corolla if you got say $20,000 or so (have not checked the price in a few years)
    I would suggest unless you are using your car for a lot of competitions, you would be wasting your money on a front LSD. You would also be adding another 20kg+ to the front of an already heavy fronted car.
    Just my 2c
    Jan 2007
    queensland
    thats shit... even my takai toymods search with GT4 LSD didn't bring up that much info...
    cheers for your help + rep
    Jun 2009
    Correction on the All ADM 185s have a rear LSD, that is untrue and i wish that it was the case! Mine is open along with others from Ozcelica.com
    90' GT-Four ST185 RC motor ST205 gearbox!
    New installs Ct20B and Rear Strut Brace!!
    Next to come;
    3SGE cams, Fidanza Adj Cams, WolfKatz fuel rail!!
    mattysshop: much lolz, i searched the GT4 thread for "Front LSD" and remembered to look for MWP's post - he deserved the rep.
  1. RA23/28 Factory Specs - for the life of me, Please!
    By bugeyedcreepy in forum Tech and Conversions
    Last Post: 21-05-2007, 12:20 PM
  2. Replies: 51
    Last Post: 21-08-2006, 12:10 AM
