Results 1 to 12 of 12
Thread: Dropping #1 Cylinder on 4afc
    Junior Member Grease Monkey ra65's Avatar
    Default Dropping #1 Cylinder on 4afc
    Hi Guys,
    I am dropping number 1 cylinder on 4afc in a 1990 corolla. Have so far replaced:
    Cap
    Rotor
    Plugs
    Leads
    Will always be dropping at idle, car is low on power, getting around 250km per tank of fuel driving around.
    What else should I look at? Any ways to easily narrow down the problem?
    Hooligans Holiday Grease Monkey kickstartRA28's Avatar
    Apr 2009
    Default Re: Dropping #1 Cylinder on 4afc
    Do a compression test on the engine might have a burnt valve, blown head gasket or something along those lines........
    3TGTE might be old but it can still hammer along.
    Tallahassee, FL USofA
    What's the compression?
    Pulling the injector or plug wire to find out which one?
    Swapped injectors?
    Thanks RT40Corona4AGTE.
    Quote Originally Posted by allencr View Post
    Swapped injectors?
    are we talking 4afc here or 4afe? as the title states 4afc, but this post makes me think otherwise?
    Its carby. Pulling lead to test.
    3RZFE-T Backyard Mechanic
    Nov 2008
    queensland
    Maybe a cracked piston or a burnt valve
    Had any bad pinging lately?
    +1 for compression test. . . . . please let us know what you find? (if you get poop readings here, try the oil down the spark plug hole trick and repeat test) this would indicate worn rings/piston damage. If readings dont increase after oil, check out the valve train and perform a leak down test.
    Would it be worth changing out the coil?
    If its piston / valve / any other big job I don't think it will be worth fixing. How much does a compression test set you back?
    whereabouts are you in QLD, I have a comp tester!
    One would think the coil would make all cylinders miss and carry on, not just one of them.
    Quote Originally Posted by RT40Corona4AGTE View Post
    I am in Brisbane, Taringa.
    Yeah I was thinking that, changing all the ignition components (except coil and ignitor) actually seemed to make it slightly worse.
    Chiba
    You've tried pulling the ignition leads of one by one to see if it makes a difference?
    Aug 2010
    Think about the basics: fuel, air, compression, spark.
    Fuel: Its a carby, so any problem is gonna affect all cylinders, not just one. Rules this out.
    Air: It's possible there could be an issue with the intake valve. Easy to check if it's opening/closing properly, turn it over by hand with the cover off. Anything else would affect all cylinders.
    Compression: the most likely suspect. Compression gauges are like 30 bucks from SCA, and are very useful. A problem in the head is easier, a problem in the block would probably be terminal in your case.
    Spark: Already checked out the plug and lead. Make sure the dizzy contacts are all good. Coil and other stuff will affect all cylinders.
  1. TA22 Brake Master Cylinder options...
    Last Post: 09-04-2022, 06:31 PM
  2. Celica 2T / 2-TG / 2-TGEU / and 3T series engine specs *sticky*
    By toyboyracer in forum Tech and Conversions
    Last Post: 14-07-2010, 09:11 PM
  3. RT104 corona clutch slave cylinder
    By StuRT104 in forum Tech and Conversions
    Last Post: 17-05-2009, 06:32 PM
  4. 4AGE 100kw into AE92 (where 4AFC used to live)
    By Grega in forum Engine & Driveline Conversions
    Last Post: 24-07-2008, 06:53 PM
  5. JZA70 Master Cylinder in RA23 - Advice Please
    By fuzz! in forum Tech and Conversions
    Last Post: 26-02-2006, 05:08 PM
