The starter motor usually does not have a fuse.
If the signal wire is off and it still turns then its likely that the solenoid itself is stuck. Try whacking it.
Permanent solution, is to remove the starter and disassemble the solenoid bit, give it a birthday. (clean it up, new brushes if required).
