Results 1 to 6 of 6
Thread: Injector issues - 7MGE - FIXED
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    Default Injector issues - 7MGE - FIXED
    I've got a 7MGE thats only running on 4 cylinders 1-456. 2 and 3 fail to work. Theres voltage at the plugs, I've tried different injectors but still no go.
    I'm stumped as to what I can do next.
    AE93 SX - Thrasher 20V
    JZX100 Chaser - Daily 1J lovin
    RAAFENG Domestic Engineer punkture's Avatar
    Apr 2008
    Default Re: Injector issues - 7MGE
    low impedanceinjectors? sounds like no ground mate =)
    Current: 1990 ST185R Celica:
    http://www.toymods.org.au/forums/showthread.php?t=62315, DAEWOOOOO ESPERO
    Previous: Ta22 4aGZE; Older: 99' WRX Impreza 192kw
    South Austrlia
    Nah I'm using all the same injectors. They all click and have the correct resitance as I tested them with a multimeter.
    Its putting out 2 codes 24 and 41.
    Wiring diagrams show that injectors 2 & 3 are on different injector drivers so it's unlikely to be that
    And it sounds like you've made sure that the injectors are working...
    Have you checked compression on clys 2 & 3?
    What about spark?
    I can't find code 2 listed...
    24 = Intake Air Temp
    41 = TPS
    http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=26
    Wilbo's JZA80
    Wilbo's JZZ12
    Apr 2008
    Quote Originally Posted by Adash=P View Post
    stupid question but can you smell fuel?
    South Austrlia
    First of all, thanks for the tips and help.
    After so much swearing and frustration it turned out to be two dud spark plugs (fucking bosch junk)
    I made a newb mistake and deserve a flaming.
    I replace the 2 with some old trusty NGK's and schweet as. No codes, smooth running
    Bianca FTW
  1. Using 7MGE Injectors with 7MGTE ECU
    By JZA70R_92 in forum Tech and Conversions
    Last Post: 05-02-2009, 05:48 PM
  2. 7MGE and LPG
    By joecoolmk2 in forum Tech and Conversions
    Last Post: 02-05-2007, 12:04 AM
