Results 1 to 15 of 18
Thread: engine crane wont jack/lift
    May 2006
    tas
    Default engine crane wont jack/lift
    hey guys.
    pulled the crane out to start swinging motors around again and the ram wont lift the arm.
    its a china supercheap item (TWN imports one) was brought new and had been used a few times them folded up and stored for 12months, so it hasnt done SFA work.
    oil seemed a bit low so i topped it up with hydro oil. also its still in as new condition and has no obvious external oil leaks, may have been low out of the box, not sure.
    when you pump the handle the arm lifts about a inch, then when you pull the handle up to go for the next pump the arm lowers a inch (SO YOU GET NO WHERE FAST!!!).
    the arm is able to be lifted by hand.
    seems me to me that these a 1 way valve in it thats fubar. if someone has experienced a similar problem or is a hydraulic expert feel free to make a suggestion of something i can try. will be calling around some shops tomorrow.
    thanks
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    Default Re: engine crane wont jack/lift
    bled air out of it?
    May 2006
    tas
    how do i do that?
    -JZX83 in the build
    <3 7M sludge pump
    in my "manual" it says
    It is possible that that air has got into the hydraulic system, causing poor lifting performance. Purge any air from the system by fully opening release valve (turn handle counter-clockwise as shown), then while holding the boom down, operate pump handle rapidly several times.
    however there is no picture to look at
    give it a crack?
    May 2006
    tas
    i have my manual and it doesn't mention a bleeding procedure! talk about slack.
    thanks, ill give it ago!
    -JZX83 in the build
    <3 7M sludge pump
    May 2006
    tas
    the old man was mucking around with it making shit worse lol. gave it a bleed as you described, same as before.
    took the ram off the crane, if it has no load at all it will fully extend, if you put any pressure on it and try and keep pumping it stops extending and just pops up and down a few mill.
    -JZX83 in the build
    <3 7M sludge pump
    Chiba
    pull it apart and take the seals to your local bearing place to match up with replacements. Ask for viton (it will cost a little more) and you will never have to replace them again.
    Nov 2007
    Hate to ask the obvious but you screwed in the release valve yeah? If so sounds like it might be leaking.
    Glen
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
    Junior Member Grease Monkey tojo's Avatar
    Aug 2009
    Norway
    If possible check for foreign object in release valve causing it to not seal
    KE17 TE38 KE35 KP61 KZN130
    Tallahassee, FL USofA
    It's full of air, either from sitting on its side & being extended & pumped, or the pump's inlet check valve is clogged closed.
    might be low on fluid.
    May 2006
    tas
    Quote Originally Posted by TERRA Operative View Post
    im thinking that there are probably more seals inside i wont be able to get at, id rather do this then buy another replacement one made out of chinese babies.
    Quote Originally Posted by tojo View Post
    old man had it out and put it back in, ill have anotehr look myself but it doesnt seem a problem there as if you extend it then apply pressure (i was hanging off the end of the crane arm) it wont compress, it stays solid.
    Quote Originally Posted by allencr View Post
    ive tried the bleeding prosedures as mentioned by olds at the start of the thread a couple of time, is there another way to bleed?
    Quote Originally Posted by The Witzl View Post
    it was low but has been topped up. no visable leaks appart from a little weeping from around the pump seal but it was like that the first time i used it when it worked.
    Quote Originally Posted by GT1978 View Post
    Glen
    yeah mate, ofcorse it was screwed in
    -JZX83 in the build
    <3 7M sludge pump
    Aug 2009
    Norway
    Try the bleeding procedure with the oil filler cap off
    May 2006
    tas
    tried that the order night, made no difference.
    took it to a hydraulic place, they are going to look at it tomoz and let me know whats wrong and costs. really need it soon as i need the engine in so i can figure out other parts that i need to order, buy, make.
    -JZX83 in the build
    <3 7M sludge pump
    or get a replacement ram?
  1. Toyota BEANs, Multiplex etc
    Last Post: 14-12-2016, 07:21 AM
  2. MA70 --> JZA70 Conversion
