Results 1 to 6 of 6
Thread: Implications of running clutch plate smaller than fly & pressure
    Default Implications of running clutch plate smaller than fly & pressure
    Hi all, I wanted to find out what the implications are of running a clutch plate that is 10mm smaller in diameter than what was designed for the particular flywheel and pressure plate?
    The clutch plate will be in complete contact with the flywheel & pressure plate face. But there will be 5mm or so of 'unused' surface around the outside of the plate.
    I would like to run this plate as it's good and it's free.
    Thanks
    Joel
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    Oct 2008
    TAS
    Default Re: Implications of running clutch plate smaller than fly & pressure
    go for gold i say.
    1983 Toyota Celica Supra
    well all I can see happening is the potential for the pressure plate to develop a ridge over time. I theory this could be an issue if you where going back to the ideal friction plate size but I seriously doubt it could ever wear enough for this to any real world effect, and besides you would just fit a new pressure platee with the new clutch. So I am with supraman above
    Why am i always a.. Domestic Engineer RAAAH23's Avatar
    Jul 2009
    New South Wales
    The sayin goes nothings ever free.
    Theres two things i can think of. You will need to replace it earlier and the flywheel will definatly need to be machined for the reason Sam stated above. I know its best to get the flywheel machined everytime you change your clutch but sometimes if the monies are tight you can get away without it. But if i was in your situation id do it.
    Cheers, Alex
    - 1976 TA23 2T-GTE GT3076 ID1000cc E85 Haltech PS1000, W58, G Series Diff, B45 Simmons
    Goodo that is what I like to hear..
    I could always get the step in the flywheel machined to the size of the clutch disc but probably not worth it.
    Also, can you machine a pressure plate surface?
    I am annoyed as brand new $500 clutch/pressure plate and i've had too much preload on the hydraulic clutch slave and clutch done a few thousand km but developed hotspots on the pressure plate.
    Would like to machine it as was custom built job.
    Ive been told by a clutch place you cant machine the pressure plate. Not sure if that was from a couldnt be bothered point of view or safety.
  1. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 11:12 PM
  2. HKS twin plate clutch for JZA80
    By Draven in forum Tech and Conversions
    Last Post: 15-04-2006, 08:44 AM
  3. Grease on flywheel / rear clutch surface..wtf!
    Last Post: 27-03-2006, 01:14 PM
  4. twin plate clutch over a single plate 6 puck carbon version
    By devil_rolla in forum Tech and Conversions
    Last Post: 02-03-2006, 11:20 AM
